Turning between centres on a Cowells CW lathes
Home › Forums › Manual machine tools › Turning between centres on a Cowells CW lathes
Viewing 15 posts - 1 through 15 (of 15 total)
  • #411253
    Nigel Watts
      @nigelwatts49512
      I would like to be able to turn between centres in my Cowells CW lathe but I can't work out how to do it as the faceplate can't be fitted as well as a centre. The only thing I have come up with is a specialist carrier which is fitted like a collet. Cowells don't supply one but they can be bought at a price from Bergeron. Any ideas?
      #13529
      Nigel Watts
        @nigelwatts49512
        #411260
          You could go 'back to basics' and try turning between dead centres, with a bow
          But may I suggest that, for inspiration, you look at the driving plate mentioned here: **LINK**
          https://watchmaking.weebly.com/other-lathe-attachments.html
          … incidentally, that ^^^ is an extensive, and remarkably good site.
          peak4
            @peak4
            If you have a chuck, use that to hold a bit of scrap bar and turn it down to a point; there's your nice new guaranteed true dead centre. Maybe even use a square bar in a 4 jaw and turn a parallel section behind the point so you can clock it for re-use.
            Drive the workpiece with a right angled carrier/dog off one of the jaws.
            Bill
            #411265
            John Reese
              @johnreese12848
              Posted by peak4 on 27/05/2019 22:14:18:
              Bill
              That is exactly what I do on my lathes.
              #411277
              Hopper
                @hopper
                Using the chuck as mentioned above has the advantage too of placing the centre to the right hand end of the gap in the bed. So you don't have to wind the carriage half off the bed ways to turn the far left hand end of the job between centres. A centre straight in the spindle is actually fairly useless on most gap bed lathes.
                Here's a couple pics of a simple drive dog for use with the centre in the chuck that I made up from some scrap aluminium flat bar, about 12mm x 50mm or so.
                Edited By Hopper on 28/05/2019 06:01:36
                #411283
                  Same as above, a cranked driving dog located easily against a chuck jaw.
                  #411289
                    Posted by Hopper on 28/05/2019 05:46:02:
                    True … but have you looked at a Cowells CW ?
                    Hopper
                      @hopper
                      Only pics. They are thin on the ground around here. Probably all got used as stock feed during the war. Seems to have a gap. But toolpost well forward of the carriage, which is less than ideal. But hey, whatever works.
                      #411298
                        The main difficulty, for the work that Nigel is doing [likely to involve use of a graver], probably relates to the 'human interface' rather than the risk of winding the carriage half off the bed ways.
                        It's quite a small machine; and a clean & compact drive arrangement for between centres work gives more clearance for hands, and better sight-lines.
                        http://www.cowells.com/docs/90cw.pdf
                        https://watchmaking.weebly.com/cowells-90cw.html
                        Edited By Michael Gilligan on 28/05/2019 09:10:05
                        Edited By Michael Gilligan on 28/05/2019 09:19:00
                        Edited By Michael Gilligan on 28/05/2019 09:21:37
                        #411332
                        Nigel Watts
                          @nigelwatts49512
                          Lots of great ideas, as ever – Thank you.
                          The Cowells CW is a bit of hybrid between a watchmakers' and a regular lathe. The headstock and tailstock are both set up for use with 8mm watchmakers' collets and both have a drawbar. Unlike a watchmaker's lathe however there is a big gap in the lathe bed to accommodate larger chucks and bigger diameter work. These chucks screw onto an adapter which in turn is fitted to the headstock with three bolts, meaning that a centre cannot be fitted at the same time.
                          As Michael says, I am hoping to user a graver for the work when turning between centres so the gap should not be an issue so long as I can position the handrest securely over the gap. Holding some bar in a chuck and turning it to a point is a good idea. It will need to be trued up again each time it is used I guess, but this should not be too onerous. I will need to acquire or make a suitable lathe dog however.
                          A watchmaker would probably use one of these, but they are not cheap:
                          Edited By Nigel Watts on 28/05/2019 12:57:47
                          #411336
                          Roderick Jenkins
                            @roderickjenkins93242
                            Not difficult to make from an 8mm blank end arbor from RDG **LINK**
                            Rod
                            #411337
                              Posted by Roderick Jenkins on 28/05/2019 13:21:39:
                              Rod
                              … and it could end up looking remarkably like the one that I mentioned in my first response
                              angel MichaelG.
                              [quote]
                              [/quote]
                              #411338
                              Nigel Watts
                                @nigelwatts49512
                                Thanks Rod – I have used blank 2 MTs from RDG to make wheel mandrels but I wasn't aware you could get 8mm collet style blanks too. The only thing it doesn't seem to have, based on the picture, is the pair of keyways on the shank but I guess these are not essential. Ordering one now!
                                #411339
                                Nigel Watts
                                  @nigelwatts49512
                                  Thinking about it, without the keyways it probably won't fit into the headstock. I guess I could anneal it and put some in?
