Today’s delivery
Today’s delivery
Home › Forums › The Tea Room › Today’s delivery
Viewing 25 posts - 1 through 25 (of 37 total)
  • #488124
    David George 1
      @davidgeorge1
      I have ordered a packet of 5 mm LED lamps yesterday afternoon and here is the delivery box.
      It must have cost a fortune to send all that air.
      David
      #36001
      David George 1
        @davidgeorge1
        #488126
        Dalboy
          @dalboy
          And I thought my delivery was bad back in January from Axminster tools. I purchased a granite surface plate and a pack of hacksaw blades the surface plate was in one box and the blades well take a look as I took this at the time of opening.
          Box
          #488127
          Dennis D
            @dennisd
            I worked at a car dealership in the parts dept and spoke to the Wurth rep about why they sent small items in big boxes. He told me that it was cheaper doing it this way than taking the cost hit resending out the small item in a packet that had been lost in the back of the courier van,
            #488128
            Mike Poole
              @mikepoole82104
              Amazon also use inappropriate boxes sometimes but a friend who is involved with their warehousing systems told me the packaging is specified by the system and not the operators.
              #488136
                Posted by David George 1 on 29/07/2020 12:29:25:
                But presumably it cost you nothing
                Actually … I believe RS has a very special ‘quantity deal’ with ParcelForce, and it probably makes a lot of sense in that context.
                Nick Clarke 3
                  @nickclarke3
                  And if there is any automated handling involved, same sized boxes would help I suppose.
                  #488138
                  larry phelan 1
                    @larryphelan1
                    It,s just more junk for us to get rid of.
                    Reminds me of the amount of rubbish I end up with after shopping for the few items I need, week to week.
                    #488140
                    Martin Kyte
                      @martinkyte99762
                      Well at least it's cardboard, sustainable sourced, no polystyrene. Assuming that the delivery lorry wasn't full so it doesn't generate an extra trip the fuel costs would be not really any more (not much extra weight) and you get a usefull box to reuse. Intuitively it looks a waste but actually probably not much.
                      regards Martin
                      #488142
                      Former Member
                        @formermember32069
                        #488144
                        Henry Brown
                          @henrybrown95529
                          I had this 200mm grinding wheel come from Cromwells yesterday. I was somewhat alarmed at how it was able to bump about in the box as the air bags weren't doing much.. The wheel rings ok so all's well but I'd expected better from Cromwell, I chose to buy from them but the local store but no stock of this wheel so had to go on-line.
                          #488145
                          Nicholas Farr
                            @nicholasfarr14254
                            Hi, I suppose it is cheaper to have a relatively few different "One size fits all" boxes rather than having hundreds of different size boxes and the there is all the bins that store them ready for use, plus the time it takes to learn how each one is opened up and folded, as no doubt they all come flat packed on a pallet. On the other hand, in this present situation, there maybe a shortage of supply and they are using what they have most off.
                            Regards Nick.
                            #488147
                            Martin Connelly
                              @martinconnelly55370
                              I recently gat something from RS in an RS branded jiffy bag. However I think they put ESD items in cardboard rather than plastic lined bags to avoid static even though the LED bag is (theoretically at least) anti-static. The point made by Dennis regarding resending costs may come into play with ESD items.
                              Martin C
                              #488158
                              Nick Clarke 3
                                @nickclarke3
                                Posted by Henry Brown on 29/07/2020 14:15:26:
                                I remember seeing something on BBC's Tomorrows World (Now there's a blast from the past!!) years ago about some research into dropping an egg loose in packing. As far as I recall the space around the object didn't matter because if you shake the box the contents will just hit the soft cardboard and if something presses against one side it will move within the box and so not be harmed. Can't remember much more, but that is the gist of it.
                                Mind you it might be just a big box!!
                                #488159
                                Swarf, Mostly!
                                  @swarfmostly
                                  Hi there, Henry,
                                  Sorry if this is off-topic.
                                  I was told by the guy in my local branch of Cromwell's that I'd have to buy grinding wheels via their web-site – they didn't stock ANY grinding wheels in the shop because they have a shelf life?!?!
                                  Best regards,
                                  Swarf, Mostly!
                                  Edited By Swarf, Mostly! on 29/07/2020 16:32:37
                                  #488162
                                  jimmy b
                                    @jimmyb
                                    Some wheels do have a "use by date".
                                    Jim
                                    #488168
                                    Martin Connelly
                                      I think some resinoid bonded wheels have a shelf life, vitreous bonded do not. We had resinoid bonded off hand grinding wheels that had a 2 year shelf life according to the manufacturer. When we pointed out there was no manufactured date on the ones supplied so we had no idea how long they had sat on a shelf they supplied new replacements with a date on, a serial number and a certificate . Not cheap wheels at 600mm diameter and 50mm thick.
                                      Martin C
                                      Edited By Martin Connelly on 29/07/2020 18:30:46
                                      Edited By Martin Connelly on 29/07/2020 18:46:11
                                      #488169
                                      Henry Brown
                                        @henrybrown95529
                                        Posted by Nick Clarke 3 on 29/07/2020 16:29:21:
                                        Nick, the problem with that theory is if it moves too much in this case it can break the side of the box out as I have had happen before, there was precious little tape around the box….
                                        Swarf, ok, the lady I spoke to did actually check if there were any stock in Evesham and didn't mention that. At the rate I go through grinding wheels I hope they have a long use by date as this is the first I've ever bought!
                                        Anyway, fitted now and all good – it ran very smoothly too…
                                        #488187
                                        V8Eng
                                          @v8eng
                                          During lockdown RS have sent me several parcels in more than one box size also a large bag containing some flexible conduit.
                                          As far as I am concerned the combination of RS and Parcel Force has provided superb service, all deliveries on schedule and well packaged.
                                          Considering that we are still in a Covid Pandemic the use of odd boxes is hardly worth bothering about (IMHO).
                                          Edited By V8Eng on 29/07/2020 21:09:17
                                          #488200
                                          Halton Tank
                                            @haltontank
                                            #488207
                                            Enough!
                                              @enough
                                              One thing we lost when 'Peanuts' became non-u, was decent packaging.
                                              Before then, all the packer had to do was dump a layer of peanuts in the bottom of the box; put the goods on top in the obvious position (in the middle) and fill up the remaining space with more peanuts.
                                              It then ticked all the boxes for decent packaging: goods protected on all sides (and especially corners) and no loose space in the box (which protects the box and therefore further protects the goods).
                                              Modern packing material is as often abused as used. Putting the goods in an empty box (especially in the corner – OMG!) then putting packing material (however good) on top (or even top and sides/ends) makes packaging engineers laugh like drains. Most wouldn't survive standard drop tests.
                                              Edited By Bandersnatch on 30/07/2020 01:25:46
                                              #488215
                                              Dr. MC Black
                                                @dr-mcblack73214
                                                I ordered a yard length of #10 – 32 studding from the only United Kingdom supplier that I could find.
                                                It came wrapped in a layer of bubblewrap in a 3" diameter tube.
                                                It was bent.
                                                I rang the supplier and explained that I was NOT happy that the studding was bent.
                                                They offered to send another length – which duly arrived unwrapped in another 3" tube. It was bent.
                                                I rang and suggested that they sent the studding taped to a piece of one inch steel angle or a length of 2"x4" timber. They sent me a refund!
                                                The courier was Parceforce
                                                MCB
                                                #488248
                                                Brian Wood
                                                  @brianwood45127
                                                  I have had several deliveries of long slender items from metals4U that are taped securely to lengths of timber longer than the items they are protecting before being wrapped in yards of cling film over the whole combination.
                                                  Without fail, these arrive intact and undamaged. They use a variety of couriers
                                                  #488249
                                                  KWIL
                                                    @kwil
                                                    Out of curiosity, was the protecting tube bent or damaged?
                                                    #488253
                                                    R Johns 1
                                                      @rjohns1
                                                      My very first online order was for a computer CD Rom (remember those). It came in a standard CD case. My neighbour alerted me that that had my parcel. They then retrieved a box big enough for a small fridge!
