TCT LATHE TOOLS
TCT LATHE TOOLS
Home › Forums › Beginners questions › TCT LATHE TOOLS
Viewing 9 posts - 26 through 34 (of 34 total)
  • #66874
    Ian S C
      @iansc
      Peter, the power hacksaw blade is about .050″ thick. Ian S C
      #66904
      Peter G. Shaw
        @peterg-shaw75338
        0.050″ thick equates to 1.27mm. So it is just under twice my normal hacksaw blades. Which means that they will be much stronger and therefore less brittle. Could be worth trying sometime if I can find a scrap one.
        Thanks Ian.
        Peter G. Shaw
        #66918
        Ian S C
          @iansc
          When I first got my lathe, one of my first projects was a replacement set of radiator nuts for a Lanz Bulldog tractor, these were made of bronze 2″ dia, threaded 3/4″ BSP, so the 16 bits of bronze had to be parted off some how, and the bit of saw blade was all I had, it worked well, even though some one told me I might have a bit of trouble with it. Ian S C
          #66926
          Gordon W
            @gordonw
            Hi, Ian, off topic I suppose, but. I’d be interested to know how you clamped / mounted the parting off hacksaw blade, a simple description will do. I’m in the thinking mode for a different, and cheaper parting off tool.
            #66927
            Ian S C
              @iansc
              he holder is a bit crude, the part that fits in the tool post is made of 2 bits of1″x !’ X 1/4″ angle iron, the blade is held on a piece of 1/4″ plate with a recess a few thou less than the thickness of the blade and held against the angle iron with 6 1/4″ bolts, the holder is about 3″ long. There you are, as clear as mud, Imight try and get a photo of it, you’ll then see how rough it is. Ian S C
              #66928
              Ian S C
                @iansc
                he holder is a bit crude, the part that fits in the tool post is made of 2 bits of1″x !’ X 1/4″ angle iron, the blade is held on a piece of 1/4″ plate with a recess a few thou less than the thickness of the blade and held against the angle iron with 6 1/4″ bolts, the holder is about 3″ long. There you are, as clear as mud, Imight try and get a photo of it, you’ll then see how rough it is. Ian S C PS I tried making a parting tool to fit it out of a bit of a Tungsten Tip cicular saw blade, but the tip fell of, I do on occasions use the little tips on lathe tools.
                #66961
                Gordon W
                  @gordonw
                  Thanks for that, think I understand, but not be doing anything for a few days. The septic tank has thrown a wobbley and wife says it must be fixed.
                  #66968
                  Ian S C
                    @iansc
                    Hi Gordon, I won’t say anything about septic tanks, I’v got one, and its OK at the moment, so I’m not tempting fate. Ian S C
                    #66974
                    Peter G. Shaw
                      @peterg-shaw75338
                      Hi Gordon,
                      If you can get a look at Len Mason’s book, Using the Small Lathe, there is a line drawing of how he made his, and which I followed, suitable modified for my lathe.
                      Essentially, mine consists of a 6mm x 30mm x 80mm plate with a slot machined lengthwise slightly less than the file thickness (in my case – for a hacksaw blade it would be just under the blade thickness) and then a 3mm x 30mm x 80mm clamp plate holding it together. Clamp screws were 6 off 4BA. On the other side of the 6mm plate is a longitudinal thick bar which fits under the toolpost screws and is set to get the cutting point of the tip as near as possible on centre height.
                      Peter G. Shaw
