folding pins 3 pin plug
Home › Forums › Help and Assistance! (Offered or Wanted) › folding pins 3 pin plug
  • #862687
    Ian Parkin
      @ianparkin39383
      Can anyone help me find a supply of folding pin 3 pin plugs or ones with cables already on
      i really need one with a c7 plug on the other end
      its to fit into a kit bag but a normal plugs pins get in the way
      #862709
      Robert Atkinson 2
        @robertatkinson2
        Almost impossible to make a fully compliant BS1363 plug with folding pins. But for Class II double insulated equipment you make it work as there is no need for a electrically functional earth pin. There are /were two designs, Slimplug and Thinplug. Slimplug is the better of the two and came with a C7 connector.
        https://plugsocketmuseum.nl/GB-foldingPlug1.html
        Don’t know where to find one though.
        Edit: Lindy used to do them code 48389452 but they are discontinued.
        #862710
          Not sure whether this is a genuine Apple product or a compatible … but it’s nicely done !
          It is, however, a USB charger
          IMG_1936
          Edit: Yes it’s the real deal … the oh-so-subtle labelling is down the gulley
          IMG_1937
          #862712
          Ian Parkin
            @ianparkin39383
            Thanks robert for that…i now have a name for a brand
            and Michael i have a few devices like that but i need a mains output..none of mine seem to be able to be taken to bits to remove the power supply and replace with a mains lead
            #862713
              For information only
              … I suspect you have better things to do with your time, Ian
              https://www.ifixit.com/Teardown/Apple+5W+USB+Power+Adapter+(Folding+Pins+-+UK+plug)+Teardown/41045
              Adrian R2
                @adrianr2
                I keep the plastic plug protectors that sometimes come with new appliances, this does not save any space but does somehow makes the sticky out pins less annoying to pack.
                Lateral thinking, find something else in your kit bag that you can drill three holes into.
