Supplier of small hose
Home Forums Beginners questions Supplier of small hose
  • #7562
    edintheclouds
      @edintheclouds
      #186158
      edintheclouds
        @edintheclouds
        Hi,
        Recently purchased a used Simplex loco, only to find rubber hose has been used to connect the side tank outlets to the axle driven feed pump.
        Does anyone know where I can buy hose that will slide on 5/16" copper tube with about 1/8" wall thickness?
        Many thanks
        Les
        #186168
        mechman48
          @mechman48
          B & Q sell clear plastic hose that should fit.. 6mm id warmed up should fit.. also sells coloured if you need it to match
          George.
          #186183
          edintheclouds
            @edintheclouds
            Thanks, walked round my local B & Q 2 or 3 times yesterday, couldn't find any plastic tube.
            Cheers
            Les
            #186185
              ed
              You might find something appropriate at Demon Tweeks, or any motorsport dealer.
              Roger Woollett
                @rogerwoollett53105
                You might try Halfords for windscreen washer tube.
                Roger
                #186193
                mechman48
                  @mechman48
                  Try near where they keep the free length chains / security chains / hoses, that's where my local store has it… tends to be down on floor level… or…
                  Machine Mart .. air hose
                  Halfords… vacuum hose – 5mm
                  George.
                  Edited By mechman48 on 12/04/2015 17:40:52
                  #186197
                  Les Jones 1
                    @lesjones1
                    Hi Les,
                    Last year I bought some 6mm silicone rubber tube from this seller on ebay. This pushes over 8mm tube OK. the tube I bought was clear but he lists it in black as well.
                    Another Les.
                    #186220
                    V8Eng
                      @v8eng
                      This company seemed to have a good range on their stand at Sandown MEX.
                      edintheclouds
                        @edintheclouds
                        Thank you all for the links.
                        Cheers
                        Les
