Steam lubricators
Steam lubricators
Home Forums Beginners questions Steam lubricators
  • #85687
    Steamshy
      @steamshy
      Is it true that inline steam lubricaters have to be mounted on the same level as the engine steam intake. Will they work ok if mounted higher up above the engine
      #5980
      Steamshy
        @steamshy
        In line Lubricaters
        #85919
        Sub Mandrel
          @submandrel
          Hi Andy,
          Sorry it's taken a while for someone to spot your post. Welcome aboard.
          If you mean the displacement type with a hole in a pipe that passes through the lubricator yes they will work if higher up as the oil will be forced down the pipe by the passage of steam. May be unreliable if lower though. Try to keep close to the cylinder as there can be a time delay before lube starts getting through.
          I'd guess that other types will wormk as long as they are uphill, but I have only used displacement lubricators.
          nigel jones 5
            @nigeljones5
            pumped lubricators (ratchet type) can be mounted anywhere
            #85953
            Steamshy
              @steamshy
              Hi Nigel,
              My lubricator is just a simple type of displacement type.
              cheers, Andy
              #86005
              nigel jones 5
                @nigeljones5
                ok..simple displacement lubricators will work away from the valve chest at any level but if you move them too far away they dont get hot enough and dont work, mine didnt ! I tend to make realy big ones and make the steam inlet adjustable. remember to fit a drain cock to the bottom of it.
                #86045
                Steamshy
                  @steamshy
                  Thanks for the tip about the drain plug/cock Nigel. I am going to mount the lubricater as close to the engine as I can. I wished I had thought to make one earlier in the piece then could have attached it to the engine.
                  #86057
                  MICHAEL WILLIAMS
                    @michaelwilliams41215
                    A displacement lubricator will work OK anywhere not too far from the engine intake . Positioning of simple displacement lubricators (ie without feed control or shut off valves ) depends far more on position relative to boiler . Needs to be thought about for particular set ups but it is very easy to get it wrong and have the lubricator feed oil back to the boiler . Sometimes when actually steaming the engine but more commonly when newly shut down after a running session .
                    Generally speaking mount lubricator as far as possible from boiler and near to engine . Think about shape of feed pipe so that there is no possibility of simple gravity back feed or syphon action into the boiler .
                    Small simple type displacement lubricators don't work in the way usually described in articles .
                    Instead of steam neatly condensing and floating tiny amounts of oil out to the engine what actually happens is that the whole lubricator almost immediately on steam turn on gets filled with a foaming sludge of oil , steam and water . This foam has a tendency to expand and will leave the lubricator down any available pipe – not nescessarily the intended one . The flow of steam will usually (not quite always) flush the oily mess in the right direction when engine is running but on shut down it can simply go anywhwere .
                    Displacement lubricators depend for their action on condensing small amounts of steam so the lubricator itself and the steam bleed pipe to the lubricator have to stay reasonably cool . On a small steam plant the best you can probably do is keep them a bit below boiling point !
                    Always fit displacement lubricators on at least a short branch pipe from steam pipe where possible .
                    Full size locomotives using displacement lubricators often have an actual steam condenser made from coiled pipe , a control valve system linked to the regulator , auxilliary control valves and a sight feed system .
                    Michael Williams
                    PS: Not quite a lubricator fault as such but a cooling boiler with no open valves can create a partial vaccuum that can suck any loose oil back into boiler from lubricator , the steam pipe or engine itself .
                    Edited By MICHAEL WILLIAMS on 28/02/2012 11:37:14
                    #86091
                    Steamshy
                      @steamshy
                      Thanks Michael. you have given me something to think about with the comments you have made, I did think that the lubricater should be fitted as close to the engine as possible but certain now.
                      I can understand that steam condenses in the lubricater and also the foaming action so with that in mind I have built the steam inlet pipe slightly higher than the oil outlet pipe and hope that it will still work properly, A trial run will tell if its working. I will disconnect the oil exit pipe from the engine to try and get an idea how effective it is.
                      I know about Vacuum breaking when a boiler cools, and also the effect it might have should it suck back any oil, so I vent any steam left when the boiler has been shut down about 10 minutes later. But thanks for pointing it out.
