Stainless steel
Stainless steel
Home Forums Beginners questions Stainless steel
  • #185072
    Brian Rice 1
      @brianrice1
      how do I stop stainless steel work hardening when turning in lathe?
      #7545
      Brian Rice 1
        @brianrice1
        #185073
        martin perman 1
          @martinperman1
          I would suggest loads of coolant to take the heat away.
          Martin P
          #185075
          duncan webster 1
            @duncanwebster1
            Sharp tool with about 20 degrees top rake, I use High Speed Steel as it is sharper than carbide, reasonable depth of cut, reasonable feed rate. If you try to take a small cut at low feed it won't work. I've had really good results with tangential toolholder. Watch out for the long ribbons of swarf it will cut your hands to shreds.
            #185077
            Brian Wood
              @brianwood45127
              Hello Brian,
              Heavy feed, slow speed and use coolant. Much also depends on the grade you are machining, some like 304 are much more amenable and will turn like high carbon steels..
              Drilling is best done by 'peck' drilling and with sharp drills, but don't overload it; while swatf comes out of the hole it is OK, the instant it stops withdraw the drill and sharpen it if necessary..
              Stainless can be machined with a light cut, in that case increase the feed rate to keep a curl of swarf coming away
              #185081
              Bob Brown 1
                @bobbrown1
                Depends on the grade of stainless steel, 304, not too bad, 316 little more difficult, I use insert tooling where ever I can and I'm not convinced by the sharper debate. Drilling and tapping can be problematic and you need the correct tap or die for stainless not some cheap item.
                Bob
                #185084
                Oompa Lumpa
                  @oompalumpa34302
                  Posted by duncan webster on 31/03/2015 15:37:04:
                  and and spells will go septic.
                  graham.
                  (Spell: sliver of swarf in the flesh. Not the type my missus usually conjurs up!)
                  #185085
                  Mark P.
                    @markp
                    Never had any problems in machining stainless. Have used carbide and HSS on both 316 and 304, both worked dry.
                    Mark P.
                    #185093
                    Brian Rice 1
                      @brianrice1
                      Thank you people
                      #185095
                      KWIL
                        @kwil
                        I have used the polished high rake carbide inserts designed for aluminium (CCGT06**** ) very successfully on stainless.
