Spotting drill size
Spotting drill size
Home Forums General Questions Spotting drill size
  • #555370
    Former Member
      @formermember12892
      #28269
      Former Member
        @formermember12892
        #555372
        old mart
          @oldmart
          Any size you like, it is only for making a spot.
          #555373
          Swarf, Mostly!
            @swarfmostly
            Hi there, Bill,
            Just my two penneth – I'd say the 'spot' needs to be big enough to at least fully contain the chisel point on the first proper drill you intend to use.
            Best5 regards,
            Swarf, Mostly!
            #555374
            Steviegtr
              @steviegtr
              I only have 6mm spotting drills but they work for most sizes. I guess a really small hole spotting may be difficult. The spotting drills i have are just from Starret holesaws. They have a very fine point so are ideal & much cheaper.
              Steve.
              #555380
                Really depends on how you want to treat the hole.
                A spoting drill can also be used to camfer the edge of the hole prior to it being drilled thus saving one operation in which case an 8mm min or preferably a 10mm 90deg spoting drill would be the best option so you don't have to deburr the entry side..
                Larger still if you wanted a fully countersunk hole as the spotting drill can also pre countersink rather than going back after drilling with a CSK bit.
                I would not really class the holesaw pilot drills as spotting drills, maybe 4-facet or split point but a bit long for spotting so may wander a bit. I mostly use an 1/8" one which does for starting holes upto about 5mm, 5mm one above that or 6mm carbide one in the CNC.
