Sourcing Handwheels
Sourcing Handwheels
Home › Forums › Manual machine tools › Sourcing Handwheels
  • #14107
    Michael Cross 4
      @michaelcross4
      #512296
      Michael Cross 4
        @michaelcross4
        Does anyone know where I can buy bored and keyed handwheels in imperial sizes?
        The only ones I can find online are metric, whilst I could bore one out easily enough I don't have a means of cutting the keyway.
        Thanks
        #512297
        John Haine
          @johnhaine32865
          Can you get a metric one that's just a bit smaller and bore it out and thin down the key? e.g. get a 12mm bore and bore out to 12.7 = 0.5 inch.
          #512300
          Michael Cross 4
            @michaelcross4
            Boring one wouldn't be a problem but I don't have a way of cutting the keyway.
            #512301
            Michael Cross 4
              @michaelcross4
              …and to be honest I'd prefer an easy way that I don't have to spend time on.
              #512305
              Adrian R2
                @adrianr2
                Buy slightly larger and wrap some suitable shimstock around the shaft, leaving a gap for the key?
                #512313
                Martin Connelly
                  @martinconnelly55370
                  Vague answer to a vague question. Grizzly.com
                  Martin C
                  #512317
                  Michael Cross 4
                    @michaelcross4
                    Thanks Martin – in an effort to be less vague: I need a UK supplier for a 6" Handwheel with a 5/8 bore and a 3/16 keyway. Are there any other details that would help?
                    #512318
                    Journeyman
                      @journeyman
                      3D print one. Loads on Thingiverse
                        Bore out a metric one then turn up a sleeve that can have a 3/16" slot cut in it so you end up with a "C" shape and then loctite that into the enlarged hole.
                        #512321
                          Better still, first result on e-bay. 6" available with 5/8 plain or keyed and from a UK maker
                          #512398
                          Michael Cross 4
                            @michaelcross4
                            Doh! how didn't I spot that? thanks.
                            #512444
                            Howard Lewis
                              @howardlewis46836
                              I like Jason'idea of a sleeve with a slot wide enough to be the keyway. Suitably dimensioned and secured to the handwheel, (With an anaerobic )
                              If all else fails, Put a close fitting sacrificial sleeve into the handle, and drill a hole of the same size as the key, centred on the boundary between Handwheel and sleeve. Remove sleeve, and file the half hole until it has square corners. Hey presto! Keyway!
                              #512454
                              John Baron
                                @johnbaron31275
                                Hi Micheal, Guys,
                                This is what I use to make keyways in a bore !
                                I've posted this before along with a drawing for the 3 mm one, though I've now done 2, 3, 4, and 5 mm keyways in pulleys both in steel and aluminium.
                                The drawing for the 3 mm one. Adjust dimensions to suit keyway.
                                #512478
                                Jon Lawes
                                  @jonlawes51698
                                  A nice solution John
                                  #512616
                                  John Olsen
                                    @johnolsen79199
                                    Do you have access to a lathe and a drill press? You don't need fancy machinery to cut a keyway, and one for a handwheel is an excellent job to start on since it is not as critical as something taking really heavy loads.
                                    I've described this technique before here, so at the risk of being repetitive… Turn a plug to fit the hole in the hand wheel. Ideally the plug should be the same or very similar to the handwheel material and should be reasonably flush both sides. Locktite it in place. Make a centre punch mark where you want the keyway, right on the line of contact between the plug and the wheel. Drill a hole using a drill just a little under the size of the desired key. Knock out the plug, and now you have have nearly 80% of the desired keyway. Take a file that will fit through the hole and is less than the desired thickness of the key. Carefully file out the corners, using the hole as a guide. You can use a piece of the keysteel as a guide to see when you are getting to a good fit. If the width is the same as a piece of HSS that you happen to have, you can also use that as a kind of chisel to help take out any high spots in the middle. Files do tend to cut more at each end unless you are very skilful with them. I have done a few keyways like this, and with patience you can get a very good job.
                                    The old timers did them like this all the time, as well as cutting the matching one on the shaft with a cold chisel and file. You can do almost any job with hand tools if you are desperate and patient enough
                                    #512692
                                    Michael Cross 4
                                      @michaelcross4
                                      Thanks for the various suggestions, I was really looking for the least possible hassle solution and in the end I found a used one.
