Afternoon,
I am looking for some solid rubber oil seals.
We have a rotating shaft that is hollow and filled with oil, there is a sleeve around the shaft with pipes connected that lets the oil flow into the shaft but stays stationary.
Inside are solid rubber oil seals that prevent the oil leaking between the rotating shafts and the stationary couplings.
I've spent most of the morning trying to find them, spoken to over 20 seal suppliers and haven't got anywhere.
The seals I took out are pretty damaged, I've found the following information in machine logs, but not what they are actually called!
Seal size I/D 68mm to 70mm ascending O/D 88mm to 92mm ascending
Can anyone advise me about these please.
