Simple Sharpening
Simple Sharpening
Home › Forums › Beginners questions › Simple Sharpening
  • #65701
    Richard Marks
      @richardmarks80868
      Gentlemen
      Does anybody out there have a simple way of touching up end mills and slot drills without the use of a dedicated machine, all i am looking for is an easily made jig that will allow me to bring the edge back, obviously if it is too far gone then a new one is the answer but I cant warrant the cost of a proper machine let alone the room taken up by it.
      Dick
      #5449
      Richard Marks
        @richardmarks80868
        #65704
        Gone Away
          @goneaway
          How about Harold Hall’s “Sharpening End Mills in an Offhand Grinder” (MEW-170).
          I don’t think you’d get much simpler.
          #65706
          Richard Marks
            @richardmarks80868
            Sid
            Many thanks for that,I used to subscribe to MEW from the beginning but I found it bcoming typecast what with scale models of lathes and drilling machines etc, I seem to recall that when this site started there was something about subscribers of ME & MEW having unlimited access to the archives, I dont recall any mention of extra charges for this service. I dont suppose I am allowed to ask if somebody can email me the appropriate pages as dont have access to the archive.
            Dick
            #65707
            NJH
              @njh
              Hi Richard
              The info. you seek is in Workshop Practice Series No 38 ( Tool and Cutter Sharpening by Harold Hall)  available, for a modest sum, from this site.
              Norman
              Edited By NJH on 19/03/2011 18:50:59
              #65717
              Richard Parsons
                @richardparsons61721
                Hi Richard,
                Although I have a homemade Stent, I also made a little jig for the smallest mills. Basically it is a Vee block with a special Clamp. This clamp carries a bar which is parallel to the ‘Vee’ of the ‘Vee’ Block. On the top of this bar is a fixture with two moveable (hardened) rollers which guide a diamond file. On the bottom there is a movable stop on which the bottom of the end mill sits.
                If there is enough interest I will find the thing and write it up.
                Dick
                #65723
                Terryd
                  @terryd72465
                  Posted by NJH on 19/03/2011 18:50:21:
                  Hi Richard
                  Hi Richard
                  £4.21 from Amazon, free delivery.
                  Terry
                  #65727
                  Richard Marks
                    @richardmarks80868
                    Gentlemen
                    Many thanks to all concerned, ordered said book plus screwcutting in the lathe from amazon, probably need a new grinder now to go with the other two, (one is for rough grinding with a wire brush on the other end) plus the 4.5″ and the 9″ angle grinders not forgetting the very useful dremmel tool, just a thought , I will now have to make more shelf space or cupboards to put all my stuff away, just how many tools do I really need?
                    and before anybody says you only need the tools required for the job in hand I defy anybody to say they have all the tools they need, you can never have enough tools, that is what SWMBO has been told,( and she believes me).
                    Regards to all
                    Dick
                    #65729
                    NJH
                      @njh
                      Hi Richard
                      ……”probably need a new grinder now to go with the other two….. “
                      Wait until you receive Harold’s book before you buy a new grinder – he has a suggestion in Chapter 13 of his book .
                      Should keep you busy for a while!
                      Norman
                      #65731
                      Versaboss
                        @versaboss
                        Posted by Richard Parsons on 20/03/2011 08:28:11:
                        Hi Richard,
                        Richard, I would be most interested in a few pictures of this gadget. I sometimes have troubles of ‘seeing’ something just from a verbal description (although in this case I see a bit, but not enough!)…
                        Greetings, Hansrudolf
                        #65755
                        Harold Hall 1
                          @haroldhall1
                          Can I clarify the information with
                          regard to the methods of sharpening end mills that I have provided.
                          That in issue 170 of MEW differs from that in my WSP book number38
                          and as Sid states regarding the MEW item, they do not come much
                          simpler.
                          That in the WPS book is much more
                          capable but still quit simple, very much so if compared to a Quorn,
                          if I dare mention that.
                          Harold
                          #65759
                          Gone Away
                            @goneaway
                            Perhaps it should also be pointed out that the MEW-170 version (and presumably the one in the book, I haven’t checked closely) is not really suitable for sharpening centre-cutting end mills.
                            (Unless Harold knows something I don’t – not an insignificant possibility)
                            #65795
                            Harold Hall 1
                              @haroldhall1
                              The answer Sid is not practical with
                              the item in MEW 170 and very time consuming to set up using either of
                              my grinding rests, as it would be if using the Quorn. In these cases
                              I do not consider it to be worthwhile, better to purchase a new one.
                              However, if one is prepared to forgo
                              the centre cutting facility it is as easy as sharpening a
                              conventional end mill, even on the device in MEW. Just grind out the
                              centre using the corner of the wheel, or preferably using a saucer
                              shaped wheel if available, and with that done sharpen it in the same
                              way as for a standard end mill.
                              I note Richard that you have stopped
                              purchasing MEW I would though suggest that you get a copy of the next
                              issue (176) as there will be an article that I have provided. This
                              giving much more detail than I have provided in the past regarding
                              using my grinding rests for sharpening workshop tools.
                              Harold
                              #65798
                              Gone Away
                                @goneaway
                                Yes, I realised the difficulty, Harold. I just wanted to point it out to Richard lest he was expecting to be able to sharpen centre-cutting mills.
                                Your point is well taken about converting them to regular end mills on regrind. Most of the EMs sold around my neck of the woods seem to be billed as centre-cutting these days although I rarely have much use for that ability. Even if I’m plunging to use an EM as a drill, I usually find it easier to drill out the centre of the hole first.
                                Does come in handy for a slot the odd time though.
                                Edited By Sid Herbage on 21/03/2011 20:50:48
                                #65832
                                Richard Parsons
                                  Hansrudolph. I went yesterday to find the thing. It and the other things in the box (jigs for making and sharpening spindle moulder cutters and all my router bits) had vanished. I know who had them and if I catch up with him it will be a dynamite enema job.
                                  I am making a series of sketches of the device but I have a simplified it for ease of construction and use. I will post these and instructions on how to ‘diddle it’ in a few days.
                                  Dick
                                  #65841
                                  Versaboss
                                    @versaboss
                                    Posted by Richard Parsons on 22/03/2011 12:14:26:
                                    A Hungarian Puszta rat? I had to look up enema; something I don’t hear every day.
                                    Don’t use too much dynamite, we don’t like colored rain over here .
                                    Sketches are ok; many thanks!
                                    #65842
                                    Versaboss
                                      @versaboss
                                      #66291
                                      Richard Parsons
                                        Hansrudolf have posted sketches and instructions in a new thread called Tool Hone
                                        Dick
