Hi Brian,
the spindle nose thread on mine is M14x1.5, but my one may not be an original spindle.
When using backgear, I completely remove the grub screw, place a few drips of oil down the hole, then use the grub screw to block up the hole again and keep the oil in (but don't do it up tight as that will lock the pulley to the shaft).
David
