Propane gas burners
Propane gas burners
Home › Forums › Beginners questions › Propane gas burners
  • #42084
    Paul Boscott
      @paulboscott25817
      I am looking for information about the construction of small propane gas burners that will run on 3 psi gas pressure ideally will look like a camping gas stove but 10mm diameter I have tried scaling one without the effect I am after.
       It looks like I need basic data so that I understand the principles of gas burner operation
      Or a nice little drawing from someone that already been there.>>
      #4703
      Paul Boscott
        @paulboscott25817
        #42087
        Geoff Theasby
          @geofftheasby
          Paul,
          The answer lies in the jet size, I think.   The burner itself is just a flame diffuser.
          Try a propane gas supplier, or website.   Different gases use different jet sizes.
          There is also the question of how much air to mix with the gas.
          The Stuart catalogue lists gas jets and burners, but for a butane/propane mix only.
          Geoff
          #42282
          Paul Boscott
            @paulboscott25817
            To answer my own question today I went in to town (Banbury) and purchased a selection of brass tube and a .005″ brass sheet (Trinders Model Shop)
            The main problem was the 0.005 hole for the jet I made it from 3 bits a cap a disk and a holder. I put the hole in the brass sheet with a tap from the small hammer on to sewing needle held in a pin chuck. Then cut the hole around with scissors fitting the 3 bits together with epoxy so that it did not leak.
            I have still to turn this prototype in to the two burners that I need but if I get it right you will be able to see them at this years Model Engineering Exhibition at Sandown.
            See my photo Album for result and dimensions
            #42412
            Paul Boscott
              @paulboscott25817
              From the prototype made from tube I have now made the two burners I was after for my engine.
              It will be at the Model Engineering Exhibition at Sandown
              See my photo Album for pictures of the burners
              #42449
              Ian S C
                @iansc
                For one of my hot air engines I made a ring burner to go round the top of the hot end.I made the jet adjustable by boring it .5mm and using a sewing needle in the end of the screw adjuster.Just past the jet are two air holes with a sleeve over the holes for adjustment of air intake,I did it this way because I hadn’t heard of the brass disc method I must try that.The burner is a hollow ring inside dia 50mm,OD 70mm x30mm high.On the inside there are three rows of 1.5mm holes about 6mm apart,the displacer hot cap is 40mm dia and is central in the hole and the flame is easy to control by ajusting pressure,jet size,air intake.Give you plenty to fiddle with if you get bored.
                #43647
                Paul Boscott
                  @paulboscott25817
                  The burners are now in position and working well the Model "Swish Stirling Twin" will be at Sandown
                  Edited By Paul Boscott on 19/09/2009 16:38:00
                  Edited By Katy Purvis on 01/06/2015 12:06:39
                  #43657
                  Ian S C
                    @iansc
                    Hi Paul,nice work,hey look as if they burn well.Is there a shroud around the hot end under normal running conditions?Like the idea for air mixing,I’v been stuck on the lab Bunsen burner type with holes and a sleeve to control the air.I started off with 3 Bunsen burners with jets for LPG.Good luck at Sandown IAN S.C
                    #43658
                    Paul Boscott
                      @paulboscott25817
                      There is not a shroud the idea is to be able to see it all working and for it to be fully transportable it can be up and running within 3 minutes of being unpacked.
                      The impetus to make this engine came from the standalone feature of the “Fire Eater Engine” and the engineering as an art form of “Halo 5” Air engine see my other videos.
                      Paul
                      Edited By Paul Boscott on 20/09/2009 06:57:19
                      #43659
                      Ian S C
                        @iansc
                        Don’t think there s a rule here(clubs may have)but I thought the flame had to be covered,its still a loverly engine,My motors are not works of art,they tend to just grow,bits added-bits taken away,not built for competion.
                        #66293
                        Ian S C
                          @iansc
                          Just a point of interest, today is the 200th anniversery of Robert Bunsens birth, although he did’nt invent the burner, he developed it. Ian S C
                          #66321
                          The Merry Miller
                            @themerrymiller
                            To follow up on your point of interest Ian if you click on the “Google” logo today you will get his life history.
