Pressure volume product
Home › Forums › General Questions › Pressure volume product
  • #109399
    Half centre
      @halfcentre
      I am thinking about a project involving a return flue boiler. The' firebox ' is simply the first section of the U shaped flue. The flue is in effect a firetube. The water operating level was usually a fairly shallow covering over the top of the flue. The latest boiler regulations refer to the 'total internal water volume' when calculating the pressure volume product. Would anyone know if there is anything different about the concept of 'total internal water volume' with respect to such a boiler?
      Many thanks
      Martin
      #22423
      Half centre
        @halfcentre
        Total internal water volume?
        #109424
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Total internal water volume is usually interpreted as the maximum amount of water contained if boiler was filled to the absolute limit of capacity . ie no steam space at all .
          Not a very meaningful concept .
          #109427
          David Littlewood
            @davidlittlewood51847
            Well, steam is still water (H2O), and I imagine the writer of the regulations had to use some figure which was capable of measurement. If you fill the boiler with liquid water it is easy to determine its capacity, but if you try to define some arbitrary typical usage level it would be impossible to have a useful definition.
            David
            Edited By David Littlewood on 20/01/2013 19:15:39
            #109433
            Half centre
              @halfcentre
              Thanks gents – so in this case as the firetube/flue can't be filled with water than this is not part of the calculation?
              Martin
              #109434
              MICHAEL WILLIAMS
                Hi Martin ,
                That's correct .
                In practice minor details of boiler design are sometimes ignored for a first estimate – using the simple external dimensions of boiler will usually give an adequate and safe figure which can be refined if nescessary .
                Michael Williams .
                Edited By MICHAEL WILLIAMS on 20/01/2013 20:21:03
                #109537
                Half centre
                  @halfcentre
                  Thanks Michael – I am trying to stay within the 3 bar litre limit, the flue will occupy a significant portion of the total internal volume of the boiler so it will effect the calculation.
                  Martin
