Parkside pneumatics
Parkside pneumatics
Home › Forums › General Questions › Parkside pneumatics
  • #554645
    Cornish Jack
      @cornishjack
      I have a few bits of Parkside pneumatic tools and a compressor with a flexible tubular outlet. The outlet male thread fits some of the items but not the particular vone I want to use. I need a male-to-male threaded metal fitting to use as an adaptor, but I don't know what the threads are. Can anybody advise please -a nd, if possible where to obtainn same.
      TIA
      rgds
      Bill
      #28262
      Cornish Jack
        @cornishjack
        #554653
        Howard Lewis
          @howardlewis46836
          Son in Law bought a compressor from LIDL.
          The tyre inflator failed. The replacement had, as expected, a 1/4 BSP thread.
          The continental connector supplied was 12 x 1. Making a simple brass male/female adaptor solved the problem.
          Edited By Howard Lewis on 18/07/2021 19:13:49
          #554657
          Clive Foster
            @clivefoster55965
            Bill
            Parkside branded tools can be a bit of a mish-mash. The accessory kits and airline proper components are almost always 1/4 BSP. In both taper and parallel versions. Don't expect all of them in any kit to be the same. I have one with kit with lost of useful parts and adapters that has taper males but parallel females. Nice roll of PTFE tape included for obvious reasons.
            Threads into tools can be either metric or UNF. If metric 10 or 12 mm in 1 or 1.25 mm pitch. If UNF 7/16 or 1/2 by 20 tpi.
            Seems to depend on what the maker had the line set up for. I've seen apparently the same tool offered at different times use different threads for the screw in fitting.
            Best to do what Howard did and make an adapter. Getting the factory fitting out is usually hard work. The contact makers have discovered high strength loctite.
            #554677
            Cornish Jack
              @cornishjack
              Many thanks, Howard and Clive.
              Looks like it's going to be a 'home-brew' adaptor – 10-12.
              Clive, you are so right about the removal – I don't know what adhesive they use, but, my word, it's very effective !frown
              rgds
              Bill
              #554696
              larry phelan 1
                @larryphelan1
                It sure is !
