Paint for diesel loco chassis?
Home Forums Beginners questions Paint for diesel loco chassis?
  • #847907
    Paul McDonough
      @paulmcdonough43628
      Dear all, I am building a 3 1/2” gauge diesel electric loco and I was wondering what to paint the chassis and bogies with?
      I don’t have spray paint gear, so it will have to be brush finish or rattle can, I can see it getting knocked a bit so a finish that can be reliably touched up would be a bonus.
      it’s mostly mild steel with some aluminium elements, what do you use to give a durable semi gloss finish please?
      #847922
      Nigel Graham 2
        @nigelgraham2
        Use an etching primer to cope with the aluminium – it will work on the steel as well.
        Otherwise, any normal, reasonable-quality paint suitable for metal will be fine – and the most expensive coach-painting finish is still not proof against chipping and scratching. That’s a matter of care in storage, transport and driving; not the grade of paint and painting.
        Though not as cheap as brush painting, aerosol paint from a motor-factors is fine for such work.
        To be honest, for the chassis I’d consider brush-painting as using a spray-can for an assembly like that would probably waste more paint on the backing than is applied to the work itself. Small brushes also reach into corners that a spray might miss. Most of the locomotive’s running-gear will be hidden anyway.
        The spray-can comes into its own more for the bodywork with its large flat or gently curved areas.
        #847964
        Paul McDonough
          @paulmcdonough43628
          Thank you Nigel,
          A appreciate your advice.
          Paul
          #848005
          bernard towers
            @bernardtowers37738
            Not sure but I think ferrous and non ferrous etch primers are different
            #848008
            Baz
              @baz89810
              Just asked Mrs Google and the difference seems to be the amount of phosphoric acid in the paint although universal etch primers are available.
              #848020
              bernard towers
                @bernardtowers37738
                Interesting reading on HUILI site.
                #848036
                Paul McDonough
                  @paulmcdonough43628
                  Cheers all
