Oil Leak on Colchester Bantam
Home Forums General Questions Oil Leak on Colchester Bantam
  • #503704
    David Francis 3
      @davidfrancis3
      Have a Colchester Bantam 1600
      It leaks oil from the headshaft behine th chuck when run at fairly fast speeds.
      Not sure if it needs oil seal replacement and what sort of job it would be.
      Any info would be appreciated
      #27735
      David Francis 3
        @davidfrancis3
        #503726
        Emgee
          @emgee
          Hi David
          You don't say if you have the manual but if not I suggest you join the Colchester iO Group where there is lots of info including the Manual FOC.
          Emgee
          #503803
          Dave Wootton
            @davewootton
            Hi David
            I've got a Bantam 2000 which used to do the same when run fast or for very long periods, Following a posting by Gray Meek about his mill gearbox leaking caused by it pressurising itself as the oil warms. I carried out the same experiment as outlined in his post, namely putting the finger cut from a nitrile glove over the filler with the plug removed, and it did inflate before it popped off, so I drilled a 4mm hole in the headstock filler plug and it has not done it since.
            According to the manual for mine there are only labyrinth seals on the spindle, not garter type seals.
            David Francis 3
              @davidfrancis3
              Hi Dave
              Thanks for the quick reply, I will give your suggestion a try.
              Many Thanks
              David Francis
