Nylon block
Nylon block
Home › Forums › General Questions › Nylon block
  • #593209
    Paul Carroll 2
      @paulcarroll2
      Does anyone know of a good source for large nylon blocks, I am trying to make several swaggering blocks to bend various shapes in brass copper and stainless. The best I have managed to come up with are only 25-30mm thick and bend too easily.
      thanks
      #28660
      Paul Carroll 2
        @paulcarroll2
        Sources
        #593291
        David George 1
          @davidgeorge1
          Have you thought of wood instead of plastic to make formers. I recently used a piece of sapele for a pattern which was tough and resilient.
          David
          #593300
          bernard towers
            @bernardtowers37738
            Wood seems to be the material of choice, use a good hardwood even glued up pallet wood
            #593305
            Paul Carroll 2
              @paulcarroll2
              David, many thanks for the response, I had not tried hardwoods as they seemed too expensive at the time (during lockdown) however I will give it a try now things are more normal.
              Paul
              #593306
              Paul Carroll 2
                @paulcarroll2
                Bernard, many thanks, I wish I had thought of that during lockdown😁😂
                Paul
                #593307
                Anonymous
                  Any commercial stockholder should stock thicker sheets, such as EDPlastics:
                  EDPlastics
                  Nylon plate up to 100mm thick.
                  However, plastic is the wrong material. Wood or metal would be a better choice, especially for stainless steel.
                  #593357
                  Dave Halford
                    @davehalford22513
                    Posted by David George 1 on 07/04/2022 07:27:36:
                    David
                    Used on the end grain like a wooden mallet
                    #593375
                    Paul Carroll 2
                      @paulcarroll2
                      Andrew, I spoke to EDP and although nylon 66 is more durable the cost of making the swageing block in hardwood (pallet blocks) is without doubt the most suitable solution and allows me to make mistakes.
                      Paul
                      #593382
                      Anonymous
                        I expected that nylon would be significantly more expensive, but thought I'd let you decide. smile
                        I make my formers out of hot rolled steel, but I normally form red hot, like the flanges on this spectacle plate from 3mm sheet:
