Concerning carbide cutting abilities the world moves on but received and published (magazine) wisdom remains largely the same. Internet and social media outpourings don’t help as they tend to multiply the repetition of the our date.
This antediluvian penguin reckons data fossilisation in teh amateur world settles at around 5 to 10 years in from the novel latest and greatest thing initially hitting the boarders of affordability and driving down into plausibly general use under the right, limited, conditions.
Certainly back in the day a major point of carbide inserts was to exploit the hot strength for heavy, hot swarf cuts going down to size in as few passes as possible. Easier cutting on hot surface leaving awesome finish on a part almost too hot to handle needing heat expansion to be taken into account when checking size. The old fart still has a few that have my massive, by most Home Shop standards, S&B 1024 working hard to get the best from them. The SouthBend Heavy 10 I had before, excellent a machine as it was in its own right, being quite overmatched.
Apart from the steadily declining cost per edge the big change I’ve seen over the years is in the steadily improvement of robustness, particularly against chipping. This modern strength has allowed sharp, small tip radius, inserts to be routinely made that are effective at very fine cuts without worrying about loosing the edge. Back in the day there was a very real risk of prematurely retiring an expensive edge due to chipping from careless manual entry in to the cut or ill constrained chatter. Found that out the hard way when trying an insert that worked well on a Colchester Triumph 2000 at work on the Heavy 10 and destroying it in nothing flat when when a gnarly bit in the material drove the job into into serious chatter. So glad I blagged, rather than bought, it. SouthBends magnificent plain bearing, cam lock, spindle on the late model Heavy 10 was well stiff enough for carbide loads but the relatively lightweight top and cross slides weren’t. Good enough for mirror finish and 10ths thou accuracy with well sharpened HSS but not strong enough for older style carbide.
