Myford var speed dc motor
Home › Forums › General Questions › Myford var speed dc motor
  • #163897
    Robin teslar
      @robinteslar
      Hi Myfordians
      I want to warn all of you about the cheap dpdt far east switch offered as a reversing switch. Dont use these, they are nasty, intermittent contacts, detent mechanism fails, wasted a lot of my time
      Whilst recovering, I read up posts about VFD drives etc and of course you pay ca £500 for a replacement (1/2hp Crompton), more than my old ml7 cost me. So I was looking at an old but serviceable scooter (rascal built for vietnam vets in the usa). Its tough stuff and the motor can put out 1hp continuous @24vdc – variable speed, but it only cost me £50 and its all working, so I was going to try it out on my ml7. Power supply up to 36vdc 40A = 2HP short bursts (does have a high temp cutout) ut that might bend my bed.
      What Im saying is that given the cost and Electrical interference, this should be a worthy opponent
      An alternative, while Im musing the scots fiasco, hope they dont believe that deceitful liar, there's also a large amount of e-bike kit that can serve as var speed motive power, these are stepper motor types but i would worry about the minute torque changes affecting turning quality?
      Not to be confused with pm motors as above.
      #23498
      Robin teslar
        @robinteslar
        using old mobility scooter parts
        #163904
        John Haine
          @johnhaine32865
          I'm, what do you mean by stepper motor type? Steppers have rather low torque for their size. Can you provide a link? Another interesting option would be a car alternator driven by a 3 phase brushless motor driver, with the rotor energised by direct current. Quite a lot of details on the web about this.
          #163906
          blowlamp
            @blowlamp
            Posted by Robin teslar on 18/09/2014 19:43:15:
            Hi Myfordians
            Which one? smiley
            Martin.
            #163907
            Harry Wilkes
              @harrywilkes58467
              Hi Myfordians
              You have to speak as you find asuming were are talking about the same switch imported from China via ebay for around £12 well I had mine on my S7 for around 18 months without problems.
              #163916
              oldvelo
                @oldvelo
                Hi Robin
                The "Heavy Duty" Electric Bike controller is probably capable of driving your 24 volt DC motor.
                They rely on the bike moving for cooling son a fan would be necessary.
                Be aware that 750 watts @ 24 volts DC = 32 AMPS current so the wiring will need to be adequate.
                My workshop machine run on 180 volts DC from a 230 volt AC speed control converter.
                This gives excellent constant speed control down to 5% of top speed.
                VFD speed control is another excellent alternative lots of info @
                http://www.powercapacitors.co.uk/products/transwave-converters/
                E ric
