Motor pulley
Motor pulley
Home › Forums › Workshop Tools and Tooling › Motor pulley
  • #267831
    sean logie
      @seanlogie69385
      I’m trying to find a 2 step pulley withe a 28mm bore and 8mm keyway …. hens teeth come to mind ,either that or I’m not looking in the right places . My other option is to bore out the pulley on my old motor ,not sure my skill level is enough to do this .
      Sean
      #18279
      sean logie
        @seanlogie69385
        #267832
        Chris Evans 6
          @chrisevans6
          It would be a good exercise to bore existing pulley. At best it works and you gain a few more skills, at worst you buy a pulley so you are no worse off. Where are you ? Help from someone may not be far away. Chris.
          #267833
          sean logie
            @seanlogie69385
            I’m kinda leaning towards boring out the old one but I’d have to do it at work on the Colchester,the keyway is the bit I’m not sure about doing,I’ve seen it being done but doing it my self is a different matter lol . I live in Nairn east of Inverness.
            Sean
            Edited By sean logie on 22/11/2016 09:19:15
            Edited By sean logie on 22/11/2016 09:21:35
            #267839
            Brian Oldford
              @brianoldford70365
              Posted by sean logie on 22/11/2016 09:17:37:
              I'm kinda leaning towards boring out the old one but I'd have to do it at work on the Colchester,the keyway is the bit I'm not sure about doing,I've seen it being done but doing it my self is a different matter lol . I live in Nairn east of Inverness.
              Sean
              Sean. The keyway shouldn't be too difficult to cut using a boring tool and following this video https://www.youtube.com/watch?v=XcU0LTavzDM There are several others.
              #267856
              mark smith 20
                @marksmith20
                Whats the size of the pulley? Is it a b section?
                #267857
                sean logie
                  @seanlogie69385
                  Mark I couldn’t tell you,the pulleys on the headstock are z .
                  The size of the pulley on the old motor is around 150 mm stepping down to half that .
                  #268045
                  sean logie
                    @seanlogie69385
                    Measured the motor pulley last night the largest od is 120mm and the smaller is 70mm . There doesn’t look to be enough material to bore it out and to 28mm cut a 8mm keyway. Looks like I’m going to struggle to keep the same gearing,this is going to be an issue isn’t it ? .
                    Edited By sean logie on 23/11/2016 13:15:19
                    #268056
                    not done it yet
                      @notdoneityet
                      I tried to post previously, but it seems to have disappeared, or maybe I thought to just let you get on with it. Should be no problem sorting out alignment as long as the pulley is not rough cast. Otherwise true up an outside face and edge using a stub mandrel before setting up for boring.
                      My more important comment was that a larger sized motor shaft usually denotes higher power transmission. You really need to consider if your machine can cope with the extra torque/power of this new motor, if it is rated higher than the original.
                      Might even require a larger section belt.
                      #268309
                      sean logie
                        @seanlogie69385
                        Hi,not done yet(liking the name ) I have considered the increase in power vs the old Fortis ,it'll be fine i thing this thing is built like a tank . I'm in the process of renewing all the bearings with better quality items . The only concern i have is that the new motor shaft is 28 mm so i wont be able to have the same gearing from the motor to the counter shaft . The size of the smaller pulley on the old motor wont allow (i think) it to fit the 28 mm shaft on the new motor . How critical will this be? . The OD of the stepped pulley on the old motor … the larger one is 120 mm the smaller is only 70 mm on a 5/8th bore .
                        Sean
                        #268324
                        Steve Pavey
                          @stevepavey65865
                          If the shaft of the motor is long enough, you may be able to turn up a disc with a boss on it, bored to 28 mm and keyed to suit. Then bore your pulley to the od of the boss, and bolt the pulley to the disc (a bit like a chuck is attached to a backplate). Without seeing a photo of the pulley I don't know whether there is enough meat on the pulley to do this – you'd need to drill and tap several holes in the body of the pulley to take the bolts.
                          #268327
                          Bill Dawes
                            @billdawes
                            Hi Sean, if you are stuck try one of the engineers stockist such as Eriks. Modern industrial pulleys are usually 'taperlock' type which has a separate bush with a variety of bore sizes for each pulley size, easy to fit as well.
                            Bill D.
                            #268328
                            Bill Dawes
                              @billdawes
                              Sorry Sean just realised your real problem, it is a two step pulley rather than a two groove pulley, still might be worth a try though.
                              Bill D.
                              #268330
                              sean logie
                                @seanlogie69385
                                Posted by Bill Dawes on 25/11/2016 10:29:49:
                                Bill D.
                                Thanks Bill ,i've just gone and ordered from Simply Bearing the exact type of pulley you've described .
                                And then I'm going to try what Steve Pavey has suggested .
                                Sean
                                #268665
                                sean logie
                                  @seanlogie69385
                                  I now have the lathe running again , I went with a 95mm taperlock pulley,which i can slide back and forth when i change pulley speeds on the counter shaft drive pulley . I've setup the motor as a counter style mount with a spring for now attached to stop the motor bouncing and it works a treat .There isn't enough meat on the old pulley to bore it out and fit a keyway . My only concern now is … will the gearing difference work now if I make a thread ?
                                  Sean
                                  #268668
                                  Howard Lewis
                                    @howardlewis46836
                                    Surely, thread cutting relies on the ratio between the Mandrel and the Leadscrew, which is determined by the change gears.
                                    The problem that you may have is not having such low speeds available, as previously; IF the ratio between the motor pulley and the Input Pulley is different..
                                    To overcome this, you could add further complication, (and pulleys and belt) by driving via a countershaft so that the speeds seen by the lathe are the same as the original motor set up.
                                    As usual one job creates at least three more than you first expected! (You would not believe how many typos came as I tried to correct the first ones!)
                                    Good luck.
                                    Edited By Howard Lewis on 27/11/2016 20:15:33
                                    #268670
                                    Les Jones 1
                                      @lesjones1
                                      I agree with Howard. The spindle speed makes no difference to the pitch of the thread. Many people rotate the lathe by hand for cutting short threads.
                                      Les.
                                      #268671
                                      sean logie
                                        @seanlogie69385
                                        Thanks Howard , I have the old Fortis up and running now so i may try a few things . I may try cutting off the small pulley off the the original and bore out the larger one to 28 mm so i would have the correct gearing on the slow speed at least . (i think that's right ….isn't it lol) .
                                        Sean
                                        #268672
                                        sean logie
                                          @seanlogie69385
                                          Posted by Les Jones 1 on 27/11/2016 20:23:36:
                                          Les
                                          Thanks Les
                                          Sean
