ML7 help please!
ML7 help please!
Home › Forums › General Questions › ML7 help please!
  • #850069
    myfordmikeml7
      @myfordmikeml7
      The clutch on my ML7 (K11860) isn’t working. I reckon it just needs a small adjustment. To get to the relevant screw, I think I need to remove the motor drive belt guard? There seems to be a hexagonal nut at the back which I have loosened but there seems to be something about halfway up on the left hand end still holding the guard. It could be an Allen (Woodruff?) key? Would that release the guard? I can’t find anything to fit it. Any ideas on size/what tool to use? The illustration in the Myford booklet doesn’t provide detail of that area of the lathe.
      I contacted Myford but they said they have no engineer who is familiar with the ML7 as it had been discontinued when they took over the business, so they have concentrated on the Super 7.
      Help please, any suggestions welcome! Thanks, Mike
      #850087
      Harry Wilkes
        @harrywilkes58467
        Hi Mike sorry can’t help but you will find the Myford Lathes group very good and helpful I think the address is
        https://groups.io/g/myfordlathes
        Good luck
        H
        #850106
        bernard towers
          @bernardtowers37738
          did it ever work or has it suddenly stopped working???? more info please
          #850115
          noel shelley
            @noelshelley55608
            There was more than one type of clutch ! One was a cone clutch, another used raleigh moped brake shoes but I think there was a third type ? Which one do you have ?  More info.  Noel.
            #850118
            Diogenes
              @diogenes
              Yes there’s a ?3/16″ BSW? nut on a stud at the upper / back, and an Allen screw in a cast-in tubular lug on the lower run that is kind of hidden within the angle of the rear ‘shoulder’ of the gear cover – it needs a 3/16″ Imperial allen key.
              It may be threaded into a ‘loose’ nut which you will need a spanner for (3/16BSW again I think), beware loose spacers / washers etc. falling out during disassembly.
              #850137
              Mark Rand
                @markrand96270
                You also need to remove the semi circular flat cover on the top right hand side of the belt guard, that’s usually 2 2BA countersunk flat head screws.
                #850177
                peak4
                  @peak4
                  Good luck
                  H
                  As is the Facebook group if you use that platform;
                  https://www.facebook.com/groups/917590484920210
                  Bill
                  #851767
                  myfordmikeml7
                    @myfordmikeml7
                    Hi everybody,
                    Thank you all so much for your help. I finally had time today to attack my lathe and the adjustment (a screw and locknut) took seconds. Everything is working as it should now. The tricky bit was getting the guard off and yes, there were two loose washers when I took the Allen screw out.
                    Many thanks again, Mike
