leadscrew pitch
leadscrew pitch
Home › Forums › Workshop Tools and Tooling › leadscrew pitch
Viewing 25 posts - 1 through 25 (of 26 total)
  • #20153
    David Keil 1
      @davidkeil1
      #525976
      David Keil 1
        @davidkeil1
        as a newbie to a milling machine, I am trying to find out what this means in relation to a leadscrew pitch, 6.3 x 1mm.
        #525979
          That's a bit of an odd one can you give us a few more details of the machine and the context of the text.
          #525980
          Pete Rimmer
            @peterimmer30576
            The pitch is 1mm David.
            #525985
            David Keil 1
              @davidkeil1
              The machine is (or will be) a Sherline milling machine. I am going to use mach3 so just trying to understand how to setup motor tuning in mach3.
              #525986
              David Keil 1
                @davidkeil1
                Pete
                what does the 6.3 relate to?
                #525993
                Emgee
                  @emgee
                  6.3 (mm?) could be the 1 decimal place American conversion of 1/4" diameter feedscrew.
                  Emgee
                  Edited By Emgee on 09/02/2021 18:55:28
                  #525994
                  Howard Lewis
                    @howardlewis46836
                    6.3 mm sounds like a slightly inaccurate 1/4" (6.354 mm )
                    Don't know the Sherline, but imagine it as a fairly small machine, so could the leadscrew be 1/4 x 25 tpi?
                    Hard to imagine that a designer would specify a 1 mm pitch for an odd diameter such as 6.3 mm..
                    It could be hybrid with a 1 mm pitch on a 1/4" shaft.
                    Having been told that the by Pete Rimmer that the pitch is 1 mm, I would expect the diameter to be a Metric integer.,
                    The essential thing is that the OP KNOWS the pitch so that he write the program
                    #525996
                      I guess this comes from Sherline's Specifications Page. 6.3mm is the diameter of their metric leadscrew.
                      Sherline's Inch leadscrew is given as ¼ – 20, which is USA speak for ¼" diameter rod threaded 20 turns per inch.
                      The metric leadscrew is given as 6.3mm x 1.0 pitch, which is similar in size to the inch version, but the dials measure in metric.
                      6.3mm x 1.0 is a non-standard metric size. I think for ease of manufacture Sherline have just put a metric 1.0 pitch thread on the same ¼" diameter rod they make ¼ – 20 from. Quarter of an inch is 6.28mm, close enough to 6.3mm.
                      For setting up CNC only the pitch matters – the 6.3 can be ignored.
                      Edited By SillyOldDuffer on 09/02/2021 19:04:06
                      #525997
                        Here it is, straight from the Sherline horse’s mouth: **LINK**
                        Standard Dimensions of Sherline Tools
                        I’ve never measured one [and there is no tolerance quoted] but can only assume that 6.3 is the diameter in millimetres
                        … either a truncated approximation for 6.35 mm, or because they actually skim down 1/4”
                        Dave beat me to the post.
                        Edited By Michael Gilligan on 09/02/2021 19:05:06
                        #525999
                        David Keil 1
                          @davidkeil1
                          The 6.3 x 1mm is the sherline specification for the x and y leadscrew axis.
                          #526000
                          David Keil 1
                            @davidkeil1
                            OOps you both beat me to it.
                            #526001
                            David Keil 1
                              @davidkeil1
                              Thanks all for your help, so simple really….haha
                              #526005
                              Anonymous
                                Posted by SillyOldDuffer on 09/02/2021 19:02:04:
                                Last time I checked 1/4" = 6.35mm – exactly.
                                In case SoD thinks I'm getting at him again, he's not the only offender who doesn't know the equivalent of 1/4" in metric, just the simplest to quote.
                                #526007
                                DC31k
                                  @dc31k
                                  We have had long and interminable discussion in another thread about various definitions of the inch.
                                  This here thread would seem to provide two more candidates:
                                  the Howard inch, where 1/4 of it is equal to 6.354mm and the Duffer inch where 1/4 of it is 6.28mm.
                                  #526009
                                  Steviegtr
                                    @steviegtr
                                    So i guess & Howard & Duffer inch is somewhere in between.()
                                    Steve
                                    #526013
                                      Would that be the "Howduff" inch?
                                      Not to be confused with the typo inch.
                                      Edited By JasonB on 09/02/2021 19:44:59
                                      #526026
                                      Clive Foster
                                        @clivefoster55965
                                        Feedscrews of metric pitch but imperial diameter has been very common on metric versions of machines originally designed for markets using the imperial system.
                                        Which can be a right pain.
                                        Telling the difference between 5 tpi and 5 mm pitch on Bridgeport feedscrews or nuts is hard enough when everything is new and factory fresh. Throw in a quater of a century of wear and its time to invent new swear words. Screws aren't too bad when you know the cunning trick to make it easy but nuts …..
                                        Many years a go I chose the best fit pair from several loose cross slide feedscrews and nuts when doing a "frankenlathe" Boxford saddle on southbend apron and bed job. I know some were metric, some imperial and all were worn. I'm pretty certain that best fit pair was one imperial and one metric but which was which I know not. Worked just fine for me over a decade or so and the guy who bought it was happy.
                                        #526035
                                        Grindstone Cowboy
                                          @grindstonecowboy
                                          Posted by JasonB on 09/02/2021 19:44:18:
                                          The "Duffard", I think. smiley
                                          Rob
                                          #526037
                                          David Marks 2
                                            @davidmarks2
                                            1/4 – 20 is a 1/4" UNC thread. A standard thread in the UNC/UNF series and the American equivalent to our BSW/BSF system of threads.
                                            #526052
                                            Oily Rag
                                              @oilyrag
                                              Some years ago I was passing through Hong Kong on my way home from China mainland, the connecting flight 'missed' so I had 48 hours in HK before I could get another flight. In this time I decided to have a made to measure suit which would be ready in just 36 hours!
                                              When I was being measured up I was surprised to discover that I had miraculously lost weight – my waist size had dropped from 34" to 27", my chest from 42" to 34"! That was when I discovered the Chinese tailors inch where 1 CTI = 1.25 Imp inch!!
                                              Martin
                                              #526183
                                              Howard Lewis
                                                @howardlewis46836
                                                My 1958 Zeus charts give 25 mm as being equal to 0,9843 inch. Dividing by 25 and multiplying by 25.4 gives 1.0000488. So The 25.4 mm to 1 inch figure that I have always used seems to be out by 488 millionths of an inch..
                                                SOD's 6.28 mm for 1/4" gives 25.12 mm to his inch. I think that the low temperatures have made his measuring equipment contract!
                                                My suspicion, in this case is that the Leadscrew is made from 1/4 inch bar with a 1 mm pitch thread cut on it.
                                                #526187
                                                  Posted by Howard Lewis on 10/02/2021 16:32:15:
                                                  No, it was my brain that malfunctioned! No idea where 6.28 = 1/4" came from. 25.4 / 4 = 6.35
                                                  Perhaps a nap would help…
                                                  blush
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    The Zeus figure is rounded. The real figure to 9 decimal places is 0.984251968", but the Zeus chaps probably reckoned that anything less than 1/10 of a thou was not for practical men. I my case anything less than a thou is a chimera
                                                    #526193
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      So we got there in the end! Now I've forgotten what we were doing.
                                                      I know, we got (lead ) screwed up
