Insert Tools
Insert Tools
Home › Forums › Workshop Tools and Tooling › Insert Tools
  • This topic has 11 replies, 9 voices, and was last updated 8 May 2017 at 19:48 by richardandtracy.
  • #295713
    James A
      @jamesalford67616
      I was wondering whether anyone has used these particular insert tools from Arceuro and whether they are suitable for a small lathe? I have a Flexispeed with a top speed of 500rpm.
      Thank you.
      James.
      #18496
      James A
        @jamesalford67616
        #295716
        Nick_G
          @nick_g
          I have used the CCMT inserts that they take at 500 rpm with reasonable results so long as the feed rate is not too fine.
          But then again it's linked to the dia and type of material you intend to cut.
          Nick
          #295730
          John Reese
            @johnreese12848
            I think the CCGX inserts would be a better choice. They are dead sharp and have a polished top face. They are primarily intended for aluminum but work very well in steel on lower powered machines. They will fit the holders you described.
            #295746
            Niels Abildgaard
              @nielsabildgaard33719
              I started with a bougth tool like shown,but made something infinitely better.
              If interested make one Yourself.
              http://www.homemodelenginemachinist.com/showthread.php?t=10175&page=2
              Edited By Niels Abildgaard on 01/05/2017 08:40:52
              #295782
              Nick_G
                @nick_g
                Posted by John Reese on 01/05/2017 05:47:25:
                Thanks for the tip. Just found some Sandvik ones 10 off for £10 on ebay (bargain) so will give them a try.
                Nick
                Edited By Nick_G on 01/05/2017 11:17:33
                #295800
                  The Flexspeed is a small lathe so I agree the ground inserts, which are sharper, should be best.
                  Ian S C
                    @iansc
                    But don't get too carried away, for a small lathe like your's most work done can be with HSS, there will be times when Tungsten Carbide is needed, castings with hard outside, some harder steels and stainless.
                    Ian S C
                    #295874
                    James A
                      @jamesalford67616
                      Thank you for the replies. I know that carbide tools are not that useful on this machine type and was aware that some inserts are carbide: hence the question.
                      I shall look at getting a CCGX insert and a holder to try out. I have been using HSS bits successfully, but like the idea of being able to just pop in a new cutter when needed without needing to reset the height. I also thought that it would a good way to compare my own tool grinding with a "known" tool.
                      The home-made holder looks sturdy; thank you for the link.
                      James.
                      #297144
                      Howard Lewis
                        @howardlewis46836
                        My understanding is that carbide tips rely on the metal reaching a temperature, locally, where it becomes plastic.
                        The tips were developed for heavy, rigid, industrial machines where a high rate of metal removal is vitally important.
                        For this to happen, usually requires high speeds and heavy feeds, which most hobby machines do not provide, or are not sufficiently powerful or rigid to withstand.
                        Having said that, many hobbyists use replaceable tips with success. A feasible alternative is to use HSS.
                        Tangential tool holders (Bought or shop made) using HSS toolbits, are particularly effective, and HSS tolerates the odd bang far better than Carbide tips (How do I know?) and can work out cheaper in the long term.
                        #297163
                        KWIL
                          @kwil
                          Ian, The right indexable tip is the best for getting under that chilled casting surface, that was my introduction to indexable tips many years ago by an ex Sandvik man.
                          #297169
                          richardandtracy
                            @richardandtracy
                            I work mostly in plastics & brass for pen making. Got a boring tool 2 weeks ago that goes down to 8mm with 10 of those inserts for under £7. Works great on my pens at 680 rpm on either the brass or plastic bits. The 10 inserts will probably last me out given that my normal most used 60 degree inserts have lasted 15 years already & I have 4 of the 10 left.
                            Richard.
