Imperial Drawbar for a Metric BF20 Mill
Home › Forums › Workshop Tools and Tooling › Imperial Drawbar for a Metric BF20 Mill
  • #228191
    Johannes Grabsch
      @johannesgrabsch91508
      I have a metric BF20 Mill with a M10 Drawbar, but also some old tooling with 3/8 threads in their MT2 Tapers. The supplier of the mill seems to be unable to supply me an original drawbar with the required imperial thread (they are metric only…)
      Before I start making a replacement drawbar there should be an obvious solution: There are many variants of the BF20 type mill around, and I guess also some imperial mills. Does anybody know weather a drawbar from an imperial Warco WM18 mill would fit into a BF20?
      Thanks
      Johannes
      #18020
      Johannes Grabsch
        #228212
        Chris Evans 6
          @chrisevans6
          Not sure of your machine but it sounds like a simple turning job to make one.
          #228217
          Roderick Jenkins
            @roderickjenkins93242
            Many people may want to close their eyes to the next bit surprise
            You can put a 3/8" Whitworth tap down an M10 thread and get satisfactory engagement with a 3/8 BSW draw bar.
            M10 = .393". 1.5mm pitch is 16.9tpi
            3/8BSW = .375. 16tpi
            A bit agricultural but it works on my mill.  The reverse, an M10 tap down a 3/8 BSW hole ought to work even better.
            Sorry,
            Rod
            Edited By Roderick Jenkins on 04/03/2016 11:03:31
            #228218
            ASF
              @asf
              I made one for my, similar, mill. A little bit more than a simple job though to be fair (well for me!). I found that, because of the length, you need to turn with tailstock support (probably obvious) but needed to use a travelling steady to ensure it was true down the entire length. I case hardened the squared end, as my original metric one had been.
              #228225
              Ian Parkin
                @ianparkin39383
                I recently went down a similar route with a selection of MT3 tooling all with different threads
                I made them all the same to M12
                Sometimes drilling out to retap and sometimes 1/2" whit just running a m12 tap down
                a few needed annealing beforehand
                if you want a drawbar in 3/8ths i have one for a wm18 machine
                Edited By Ian Parkin on 04/03/2016 11:37:48
                #228230
                HOWARDT
                  @howardt
                  Why not just pin a nut, or special end onto some studding. Simpler and no long turning problems.
                  #228232
                    Posted by Roderick Jenkins on 04/03/2016 10:59:18:
                    Sorry,
                    Rod
                    It does! I would never have admitted to doing such a terrible thing without Rod's brave example. Perhaps we should start a "True Confessions" thread.
                    Cheers,
                    Edited By SillyOldDuffer on 04/03/2016 12:09:24
                    #228273
                    Johannes Grabsch
                      I had already considered cutting M10 threads into the imperial tooling. But unfortunately the very item that I need to use has a taper that appears to be hardened, so tough is it.
                      The drawbar of the Optimum BF20 is a tricky item. I could just use a long 3/8" threaded rod, but I would loose the safe feature to push out the tool from the spindle. As ASF said, simply copying the original drawbar but with an imperial thread is a bit more complicated than it sounds.
                      I think I'll buy a spare metric drawbar and I'll braze a length of 3/8 threaded rod replacing the M10 section.
                      Johannes
                      #228276
                      John Fielding
                        @johnfielding34086
                        I have the same machine except it is the Rong Fu RF-25 as they are the makers. I have made plenty of drawbars for various bits of tooling. I use studding rod (all-thread) and sliver solder or cross pin a normal nut on the end and cut it to length. I sometimes need to make a thick washer cum stepped collar to fit the top of the quill where it comes through the top pulley. The original drawbar that was supplied seemed to be made from putty, very poor steel, the common or garden studding sells for almost nothing and makes at least two from a standard length.
                        #228281
                        Ian Parkin
                          @ianparkin39383
                          Johannes
                          heat the end of the taper up with a propane gas blowtorch untill its a red colour let it cool and you will be able to machine it then
                          I have not noticed any difference in the performance of my tooling….hardened or not on the taper
                          #228412
                          Ian S C
                            @iansc
                            I needed a 3/8W draw bar for my mill, took two bolts, cut the heads off, welded them together, the top end has a loose nut, and above that a pair of nuts jambed together, been ok for the last twenty odd years.
                            Ian S C
                            #228415
                            Howard Lewis
                              @howardlewis46836
                              +1 for making a 3/8 BSW drawbar. The one that came with my RF25 has the hexagon pinned to the top end.
                              So no reason why not to cut a 3/8BSW male on the end of a 3/8" or 19mm bar, and pin or weld a bit of hexagon bar on the other end, at the required distance.
                              (Not REALLY happy at hybridising threads, have come a cropper at times doing things like that)
                              And it is only a simple turning job to make a 3/8 BSW drawbar, anyway, so time well spent.
