HSS vs Carbide milling feeds & speeds
Home › Forums › Workshop Techniques › HSS vs Carbide milling feeds & speeds
  • #197637
      This video was posted on another forum tonight, makes interesting viewing to see how much more the carbide cutters can remove at "normal" speeds.
      PS you can skip the calculations at the start if you just want to watch the chips
      #15794
        Thor 🇳🇴
          @thor
          Thanks for posting the video Jason. Impressive amount of chips produced by the carbide cutters, I am not sure though that my milling machine is rigid enough for such depth of cuts. I have used carbide cutters when dealing with material with a hard surface or hard spots, but with small depth of cuts. Carbide cutters also seems to be more brittle than HSS.
          Thor
          #197654
          GarryC
            @garryc
            Thanks Jason, very interesting. The formula's at the start went over my head – is there an up to date 'handbook' with such formula in I've come across one from Tubal Cain but not a recent edition..? Had to look up the references to FC3 and HPC as I had no idea what there were either, so a little bit wiser now.. My Mill doesn't have auto feeds but hope to have one in the future.. I'm guessing there must a be a book somewhere with all this info in – I'll have to do some digging..
            Cheers
            Garry
            #197655
            John Haine
              @johnhaine32865
              FS Wizard for both Apple and Android devices does this well. Free lite versions for both.
              #197656
              GarryC
                @garryc
                Thanks John, had trouble finding the free iPhone / iPad download – here it is **LINK**
                and the Tutorial – http://zero-divide.net/?page=FrontPage&shell_id=151&action=search_results&search_category_id=1110&search_where=3&search_string=FS%20Wizard
                Edited By Garry_C on 23/07/2015 08:58:29
                Edited By Garry_C on 23/07/2015 09:11:58
                Edited By Garry_C on 23/07/2015 09:12:42
                #197660
                Raymond Anderson
                  @raymondanderson34407
                  I think that using a "throw away "hss cutter against a carbide end mill is not really a fair comparision.
                  even if it is as the lad said, a cheaper brand of carbide cutter. A fairer test would have been an hss Co end mill from
                  Emuge Franken , Guhring Titex or Clarkson "premium" Interesting vid though but, I feel, not cut and dried.
                  #197662
                  Ian S C
                    @iansc
                    Perhaps a comparison test between different qualities of HSS could be useful(there probably is one).
                    Ian S C
                    #197663
                    KWIL
                      @kwil
                      Yes the carbide cutters are more brittle than HSS if you insist on knocking them about. Always keep cutters separated, one from another.
                      You do not need autofeed to use carbide, but steady "engagement" is necessary.
                    Home › Forums › Workshop Techniques › Topics
