holding small screws
Home › Forums › Workshop Tools and Tooling › holding small screws
  • #229299
    ken king, King Design
      @kenkingkingdesign
      Not very technical, this, but where can I find a small blade screwdriver with means of holding 8BA or 10BA brass c'sunk screws to allow me to enter them into hard-to-reach holes ? In the past I've seen split-blades which jam into the screw slot, and other drivers with tiny spring claws, but haven't managed to locate any of them. Alternatively, a means of magnetising brass would be great !
      #18025
        @kenkingkingdesign
        #229301
          This one is in the USA so postage is more than the cost but it should get you started on google…
          John Haine
            @johnhaine32865
            Superglue? Bluetack?
            #229306
            Jon Gibbs
              @jongibbs59756
              Posted by Neil Wyatt on 10/03/2016 11:13:53:
              RS do the same screwdriver by the looks of it…
              Jon
              #229308
              Gordon W
                @gordonw
                If the position is not very difficult I just use a bit of paper, bent to suit and the screw stuck in. When the thread bites tear off the paper strip.
                #229310
                Ajohnw
                  @ajohnw51620
                  I've used a number of things including grease and marmalade. Depends on the screw size but I use angled tweezers. I obtained them from GiantCod but they have gone now but the same styles are available here
                  I also use a set of these screwdrivers but managed to do better on price
                  I wasted my money on various type before buying these. The blades are really hard and grip well. I keep meaning to make a small jig to hollow grind the tip on a dremel but haven't broke enough yet.
                  Edited By Ajohnw on 10/03/2016 11:55:43
                  #229313
                  Ajohnw
                    @ajohnw51620
                    Mmmm Qiucktest's postal charges have gone up since last time I used them.
                    Dave Daniels
                      @davedaniels93256
                      These are what I use:
                      I have used them on small screws but on the smaller UNF/UNC screws. I do know they work on 2-56 UNF but I suppose it depends on the slot width. Never knowingly used them on the BA sizes you mention.
                      Edited By Dave Daniels on 10/03/2016 14:06:56
                      #229340
                        @kenkingkingdesign
                        Thank you all for your inputs. I'm going with the R.S. tool, .020" tip width.
                        #229342
                        Ajohnw
                          @ajohnw51620
                          On microscopes I've had to go down to M1 and sometimes have to work under a desk magnifier. The main problem with the tweezers is dropping screws. Trouble with the forum – last time I looked at quicktest they didn't have the normally closed ones so just ordered some. Also the screw holder type out of curiosity.
                          The ones I bought originally came as a set of 3. 2 pretty sharp ones one of which is angled and another. I find one or the other fine for any size that I can't do easily by hand.
                          They can also be great for getting splinters out. GiantCod used to sell to model aeroplane makers etc hence the need.
                          John Shepherd
                            @johnshepherd38883
                            I keep promising myself some of these:
                            Speedy Builder5
                              @speedybuilder5
                              Follow the thread "Small Screw Gripper" on this site. wink
                              BobH
                              #229380
                              Dinosaur Engineer
                                @dinosaurengineer
                                Posted by Dave Daniels on 10/03/2016 14:04:42:
                                #229384
                                NJH
                                  @njh
                                  I certainly recommend the screw placer recommended by John Gibbs. It works a treat, is long enough to get into difficult places, and has saved my temper ( and sanity ! ) many times ! Please note though this is a screw PLACER – it PLACES the screw in the correct position to start it – it is not designed to drive it home – once started swop to a normal driver.
                                  Norman
                                  #229386
                                  pgk pgk
                                    @pgkpgk17461
                                    This link for a uk source..if it's small enough.
                                    I looked up various surgical screwdrivers with spring jaws… but the cheapest UK one was £97 + delivery + vat. Obscene price for a simple tool with a fibre handle and a lump of surgical steel..
