electrolytic derusting
Home › Forums › General Questions › electrolytic derusting
  • #597378
    duncan webster 1
      @duncanwebster1
      I've just tried this for the first time with excellent results. No surprise there, it has been widely reported. What did surprise me was the effect on the anode, which was a bit of scabby old plate, some covered in paint. All the paint very quickly fell off. Anyone know what's going on? The only thing I can postulate is that the electrolysis turns the washing soda into caustic soda, but I never was all that good at chemistry. I once answered a question in an organic chemistry exam with 'under the right conditions of temperature and pressure, anything can happen'
      #28698
      duncan webster 1
        @duncanwebster1
        #597380
        AJW
          @ajw
          I use the process for my stationary engine parts and, like you, have been most impressed even used it for the insides of petrol tanks.
          I'm no chemist either!
          Alan
          #597388
          Graham Stoppani
            @grahamstoppani46499
            In this process the electrolyte doesn't change. The paint loss is either due to the metal underneath it being eroded away on the sacrificial anode or possibly by the oxygen bubbles being formed.
            simple explanation Link
            long winded explanation Link
            #597391
            Rod Ashton
              @rodashton53132
              Thanks you Graham and thanks to Andrew Westcott in the simple link above. Excellent explanation. Both useful and timely!!!
              #597410
                Posted by Graham Stoppani on 08/05/2022 06:28:32:
                Partly , but Washing Soda (Sodium Carbonate) is a junior paint-stripper in its own right. Washing Soda and Caustic Soda are both alkalis, which attack grease and oil.
                As many paints are held together by a drying oil, they can be stripped by an alkali – it destroys the binding agent and the paint falls apart. Caustic Soda works faster because it's strongly alkaline, but Washing Soda would loosen paint even if the power wasn't turned on as well!
                Might even be essential. I think what's happening is the paint surface is first penetrated by the Soda, allowing electrolytic effects to develop behind the paint and at edges, thus accelerating it's separation by removing the supporting metal and levering flakes off with microbubbles.
                Probably best to start by removing paint first because it weakens the mix, slows down the main attack and is a bit messy, but I don't suppose it matters much!
                duncan webster 1
                  @duncanwebster1
                  The bubbles form on the cathode, the paint was on the anode
                  #597414
                  KWIL
                    @kwil
                    Posted by duncan webster on 08/05/2022 10:44:30:
                    Both electrodes will bubble, one with oxygen and the other with hydrogen.
                    #597754
                    Tim Stevens
                      @timstevens64731
                      And, to follow Kwil's comments – the hydrogen will turn red rust to black magnetite, and the oxygen will, er, oxidise anything – such as aluminium to oxide (= anodising). It can be handy to remember this, as the container can be corroded if you get it wrong.
                      Cheers, Tim
                      #597822
                      Bill Davies 2
                        @billdavies2
                        I found Graham's long-winnded link to rust removal by electrolysis very interesting. It is a collection of multiple articles in one document, so it is a bit repetitive. Anyone skipping it should note to avoid using stainless steel anodes, as (for example) comments on using stainless steel on page 11. Stainless steel produce toxic chromates and must be avoided. Now, where's my rusty angle plate I made during my apprenticeship over 50 years ago?
                        Bill
                        #597848
                        Graham Stoppani
                          Posted by SillyOldDuffer on 08/05/2022 09:59:54:
                          Did I mention that I used to be Managing Director of Turco Products Ltd? Manufacturer and supplier of paint strippers to the aerospace industry? wink Not disagreeing with what you say, just keeping it simple for the OP.
                          #597864
                          Mark Rand
                            @markrand96270
                            Posted by Bill Davies 2 on 11/05/2022 10:29:38:
                            I've only ever seen green (chromium III, Chromites ets.) colouration when using a stainless anode, not red/orange (chromium VI, the dangerous one, including Chromates).
                            Along those lines:- If you use lead anodes with washing soda, you will get lead carbonate (white lead) deposited in the tank.
                            Edited By Mark Rand on 11/05/2022 17:16:21
