Drag Engraving
Drag Engraving
Home › Forums › Workshop Tools and Tooling › Drag Engraving
  • #827232
    Alan Charleston
      @alancharleston78882
      Hi,
      I want to engrave a scale onto some brass sheet. A while ago I found a good youtube video which described how to use a spring loaded diamond grindstone dresser to do this. Alas I didn’t save the link and I can’t find it again.
      As I’m going to be engraving brass, it strikes me I don’t need a cutter as hard as diamond and a hardened silver steel tool should be OK.
      My question is – Should the tip be a cone, or a 4 sided pyramid? I’m assuming the included angle should be 90 degrees.
      Alan C.
      #827237
        The replacement tungsten tips you can buy are conical, 60 or 90deg depending on what you want the engraving to look like.
        #827254
        Nigel Graham 2
          @nigelgraham2
          For occasional work at least, and engraving only straight lines, a suitable cutter can be ground from a piece of small-diameter tool-steel, perhaps a broken or worn-out centre-drill.
          I’d certainly keep a grinding-wheel dresser only for its intended use.
          #827272
            The description seems a little garbled … but these might be useful:
            https://www.aliexpress.com/item/1005004728231734.html
            Alan Charleston
              Hi,
              Thanks for the replies.
              Nigel – The video which I now can’t find recommended using a wheel dresser because they were much cheaper than the proper diamond cutters.
              Michael – Those Aliexpress cutters look interesting. I’ve made the spring loaded holder and I’ll try a hardened silver steel cutter first. If that doesn’t work I’ll look at getting the cutters you provided the link to. They seem cheap enough to try.
              Alan C.
              #827457
              Nigel Graham 2
                @nigelgraham2
                Alan –
                Don’t over-think!
                You don’t need all this searching for special cutters for a one-off series of straight lines in a brass plate. You would only need an engraving-cutter in a proper engraving machine to form the numbers as well.
                For a drag-cutter, simply grind a piece of tool-steel to resemble an ordinary screw-cutting tool. An old or broken centre-drill or “throw-away” cutter, or stock HHS steel, is suitable material.
                For a revolving cutter, when I engraved a flat scale in stainless-steel, I used a worn centre-drill freehand re-ground to a more tapered point, in the milling-machine.
                It worked very well, without needing buy anything!
                I stamped the numbers, using a flat bar as a guide-fence for the stamps.
                (Without the proper means I could not guarantee resharpening the drill to restore its original purpose, so it was fine to use for a task like this.)
