Dead Center’s
Dead Center’s
Home › Forums › Workshop Tools and Tooling › Dead Center’s
Viewing 15 posts - 1 through 15 (of 15 total)
  • #19917
    Alan Gordon 4
      @alangordon4
      #491312
      Alan Gordon 4
        @alangordon4
        I would like to buy a couple of dead centers. I purchased two from a well known lathe supplier but found the runout excessive. Ant recommendations where I might get good quality ones ?
        #491315
        Tony Pratt 1
          @tonypratt1
          You need to send them back .Tony
          #491319
            Are you sure it's faulty dead centres Alan? You didn't get a good answer to your thread last month asking about your S7 turning tapers.
            ' Good afternoon folks, I have an issue on my S7 turning a taper. My lathe sits on a Myford cabinet. Using a test bar, a DTI and turning the "dumb Bell" I consistently get a taper ! it tends to be smaller at the headstock end. The taper however is variable. I have taken readings using different equipment.The saddle, crosslide and compound slide are smooth with no slack or looseness, As this issue is turning me to drink, I now hope some one can offer advice.'
            Can you explain what the centre trouble is? Badly made Centres are a possibility, though two duds feels unlikely. There are a few tailstock issues causing similar symptoms. Always good to see a few photos.
            not done it yet
              @notdoneityet
              ‘Well known” can cover a multitude of suppliers from UK based, US based or even Chinese. Question might be whether they have good reputations as well as being well known (hopefully the supplier is not ‘notorious’ as well as well known). There are subtle differences.
              Give us a clue. Is this supplier a well known reputable supplier? No name needed.
              #491324
              Martin Connelly
                @martinconnelly55370
                Two new tapers, one old socket? Check the socket.
                Martin C
                #491326
                Dusty
                  @dusty
                  I suspect you are talking about rotating centres rather than dead centres. Dead centres are, soft which goes into the headstock taper and is machined in situ, and hard which goes into the tailstock, which is then adjusted to turn parallel. rotating or live centres, you pays your money and takes your chance, good ones are expensive for a very good reason, don't expect to get top quality for peanuts, accuracy costs. Remember the tailstock needs adjusting even with a rotating centre to turn parallel.
                  #491328
                  Emgee
                    @emgee
                    Posted by Dusty on 18/08/2020 19:08:56:
                    If the lathe headstock and tailstock are set up correctly there should be no need to make adjustments to use any kind of centre, unless of course the centre is not accurate.
                    Emgee
                    Edited By Emgee on 18/08/2020 19:39:14
                    #491332
                    John Haine
                      @johnhaine32865
                      Dead center's what? Or dead centres?
                      #491334
                      Ketan Swali
                        @ketanswali79440
                        Having just checked our records, I am happy to confirm that the dead centres which Alan has are not from ARC. smiley
                        Ketan at ARC.
                        Edited By Ketan Swali on 18/08/2020 20:07:39
                        #491336
                        Alan Gordon 4
                          @alangordon4
                          Hi Ketan all OK I did not get them from yourselves, also folks please accept my apologies for the grammatical error ! With regards the taper I eventually carried out the carriage modification recently shown in MEW. this was a very worthwhile mod. and went some way to resolving the issue.
                          Thank you all for your excellent advice
                          #491337
                          Dave Halford
                            @davehalford22513
                            Does the runout direction move when you rotate the centre 180deg?
                            #491370
                            Dusty
                              @dusty
                              Emgee, You are right that no adjustment should be required, but it does not alter the fact that lathes especially the lighter lathes that we tend to use do alter and move over time and that some adjustment might be required. My point was do not expect it to be right.
                              #491380
                              Danny M2Z
                                @dannym2z
                                A simple test. Fit a centre in the headstock taper and the tailstock taper and bring them together trapping a razor blade between the points.
                                My C3 mini-lathe actually passed this test quite nicely.
                                * Danny M *
                                Edited By Danny M2Z on 19/08/2020 11:28:33
                                #491382
                                Hopper
                                  @hopper
                                  How did you determine your dead centres have run out? And how much?
