Clarke CL250M Spindle too Stiff?
Home › Forums › Workshop Tools and Tooling › Clarke CL250M Spindle too Stiff?
  • #531800
    Ian Mellors
      @ianmellors72388
      I've noticed that the chuck seems harder to turn than it should be, so I removed the timing belt from the motor and pulled the lead screw gears out of engagement with the spindle gear and the chuck/spindle still does not rotate freely.
      When I say not freely it turns ok, but there is resistance. It will not spin by itself.
      Is this normal? if not, I guess it's time to remove the spindle or adjust bearings? I'm pretty sure they are taper bearings, so maybe up too tight?
      Edited By Ian Mellors on 05/03/2021 09:14:08
      Edited By Ian Mellors on 05/03/2021 09:25:37
      #20187
      Ian Mellors
        @ianmellors72388
        #531801
        David George 1
          @davidgeorge1
          Is it a new machine, and is if very cold where you are, as it may change with temperature. Just a thought.
          David
          #531802
          Ady1
            @ady1
            Does sound that way
            They might be knackered, a sign of knackered roller bearings is resistance when turned by hand
            Hope I'm wrong
            #531803
            Ian Mellors
              @ianmellors72388
              Not new, 15 years old but has had very little use. It's in a pretty stable cool location (insulated loft space). If they are shot it's no biggie as spares are only a fiver each from ARC. I guess a strip down might be in order?
              #531823
              Brian Wood
                @brianwood45127
                Hello Ian
                I would try easing the preload a trifle so that the bearings are nipped rather than pulled up harder as your description implies. Then you can make a judgement on whether they sound noisy on running and act accordingly
                Regards Brian
                #531824
                Ian Mellors
                  @ianmellors72388
                  Posted by Brian Wood on 05/03/2021 10:35:44:
                  Hello Ian
                  Regards Brian
                  Thanks Brian, I'll try that over the weekend
                  #531971
                  Ian Mellors
                    @ianmellors72388
                    No such luck Brian, looks to me that the whole rear bearing at least is solid. Looks like the whole bearing is rotating in it's seat. Needs a bit more stripping down to get them out. Job for another day…..
                    #532006
                    Ady1
                      @ady1
                      At a fiver a pop I'd do both bearings and get 2 spares
                      #532038
                      Brian Wood
                        @brianwood45127
                        Hello Ian,
                        Thank you for the feedback, at least you will not be surprised by your findings, As Ady1 says, clearly the time has come to change them, they probably had too much preload applied right from the start.
                        It's easy to overdo it too, just enough to take out end float and then a bit more to the point where drag can just be detected on rotation. Back off a trifle on that and fix
                        Regards Brian
                        #532048
                        Ian Mellors
                          @ianmellors72388
                          Posted by Brian Wood on 06/03/2021 09:16:42:
                          Hello Ian,
                          Regards Brian
                          Let's just hope I can get them out…..
                          #532063
                          Brian Wood
                            @brianwood45127
                            Hello again Ian,
                            I believe ARC have a procedure for pulling the spindles on mini lathes which would be helpful for you.
                            If they are as you suspect taper bearings, with the spindle out it should then be obvious how the outer races can be extracted from their pockets
                            Regards Brian
                            #532066
                            Ian Mellors
                              @ianmellors72388
                              Thanks Brian, having taken several bits off to expose the rear bearing cover and not really succeeding in getting it out I gave the end of the spindle a good few taps with a hammer (with a block of wood over the end) and hey presto, it all freed off looks like you were right, over tightened at the factory.
                              All back together and running much better now, can get good slow speed running. Will give it a bit of a run to bed things in and recheck.
                              #532109
                              Brian Wood
                                @brianwood45127
                                Hello again Ian,
                                That sounds like good news but I fear the episode may well have shortened the life of the bearings anyway. Roller bearings, by virtue of line contact, are more forgiving than ball bearings in the same situation, as the balls concentrate any overloading and indent the bearing race(s). The process is known as brinelling. In severe cases the bearing feels decidedly 'digital' as it is rolled round and corresponding flats will have formed on the balls as well. The life left in such a bearing is indeed short.
                                I would still take Ady1's advice and get a new set in from ARC, the investment is quite tolerable and then you have them ready for change at a time to suit you.
                                Regards Brian
                                #532111
                                not done it yet
                                  @notdoneityet
                                  If that was the case, it needs to come apart now, not later.
                                  #532115
                                  Ian Mellors
                                    @ianmellors72388
                                    Posted by not done it yet on 06/03/2021 14:15:16:
                                    That was my mistake, the outer race was behind the seal plate, all rotating as they should thankfully.
                                    #532117
                                    Ian Mellors
                                      @ianmellors72388
                                      Posted by Brian Wood on 06/03/2021 14:05:40:
                                      Hello again Ian,
                                      Regards Brian
                                      Noted, I'll order some on next order with Arc. Looks like I need to remove the headstock and get the spindle pressed out. We have a press at work
                                      #532132
                                      larry phelan 1
                                        @larryphelan1
                                        Good sound advice there from Brian Wood, as always.
                                        As Ady1 says, at that price replace the lot, they are for nothing !
                                        #534335
                                        Ian Mellors
                                          @ianmellors72388
                                          Just received an order from Arc, was ordering something else so took the opportunity to order two spare bearings and a pair of motor brushes, amongst other things
