Changing a Senior M1 from Vertical to Horizontal.
Home › Forums › Manual machine tools › Changing a Senior M1 from Vertical to Horizontal.
  • #412330
    Brian H
      @brianh50089
      How easy is it to achieve the above in term of weight and awkwardness of handling of the vertical head?
      #13540
      Brian H
        @brianh50089
        #412371
        not done it yet
          @notdoneityet
          Not got one, but the Centec head weighs north of 30kg and is awkward and heavy, but I manage it reasonably well in a confined space (I’m north of 70!). That is locating it horizontally, not vertically. The Tom senior head (assuming you are referring to the S-type head) may be even heavier, so it might depend on how high you need to lift it to get it into position…
          #412467
          old mart
            @oldmart
            Looking at the lathes UK site, it would seem that your M1 has the same head assembly as the light vertical.
            The first thing to do would be to remove the motor, just the wiring to attend to, the locking adjuster and the pivot screw and derail the belt so it doesn't get caught up.. Then the two caphead screws holding the head onto the M1 adaptor, and gently work the head off of the spigot by pulling and rotating slightly. Lastly, the M1 adaptor. This breaks down the weights into three more manageable loads.
            #412468
            Kiwi Bloke
              @kiwibloke62605
              Brian, it depends on whether you're talking about removing the self-powered, quill-type vertical head or the non-quill, right-angled head (it also depends on how strong you are). The former is pretty heavy, the latter isn't. A decade ago, I could manage to manhandle the entire self-powered head onto and off the machine with ease, but a hoist seems safer, these days. The awkwardness is in getting the alignment right by 'feel', making sensitive, small positional adjustments, whilst trying not to sag or wobble under the load (which seems to increase as the task progresses), whilst balancing on some sort of step-up. Bad back = use mechanical aid!
              My Senior is a late 'Universal', with the prismatic overarm. On the rare occasions that I have removed and replaced it, it was a sphincter-tightening experience to try to align it with the female dovetail, whilst supporting the considerable weight of the thing on my (well-padded) shoulder. I had visions of the end of a dovetail cracking off. Next time it comes off, it will be with a hoist…
              #412488
              Gary Wooding
                @garywooding25363
                You can make it somewhat easier by putting a suitably sized box, or some such, on the mill table, which can then be used as jack to raise and lower the box until the VH can be transferred between it and the mill. Works fine for my Centec.
                #412489
                Brian H
                  @brianh50089
                  Many thanks for the replies, very helpful.
                  #412499
                  Kiwi Bloke
                    @kiwibloke62605
                    Yes, great idea from Gary. Centec heads weigh nothing, compared to the self-powered Senior head! cheeky
                    #412513
                    Mike Poole
                      @mikepoole82104
                      If you want to change mode regularly it would be handy to have a swing away arm to just park it out of the way.
                      #412545
                      Clive Foster
                        @clivefoster55965
                        If you plan to switch heads on a fairly regular basis you will also need some simple way of supporting the head when off the machine. If that is indeed the case consider killing two birds with one stone by making a suitably sized foot plate having a vertical arbor matching the machine taper.  Effectively the turbocharged with nitrous injection version of Garys idea.
                        When in store the head sits on the taper held nice and stable by the drawbar.
                        To fit on the machine lift the whole kit and kaboodle up onto the table and adjust until it lines up. Slide to get it roughly in place then use the table feeds for final alignment. Release taper, drop table so it clears the spindle then remove foot. Job done. Simples and no heavy lifting if you have a suitable hoist.
                        A neat side benefit is that you can fit appropriate lifting points to the foot for the hoist to hook to so it goes up nice and straight.
                        Rule one of the vertical head designers union appears to be " make it sufficiently unbalnced that it won'y hang straight".
                        Rule 2 seems to be "make the shape such that its impossible to get a stable arrangment of lifting straps without obscuring the bolting flange".
                        I have such a plate and arbor combo in the slowspeed "as and when workshop lane" as the varispeed head on my Bridgeport needs to come off for servicing in the not too far distant future. Needs an extra support at the motor end but thats no great issue as its only off for servicing.
                        Clive.
                        Edited By Clive Foster on 04/06/2019 14:01:02
                        #412584
                        Dave Halford
                          @davehalford22513
                          Pretty sure all of these were never meant to be swapped back and forth if you needed both, then buy two machines, hence the difficulty. Also you should be of a working age and know what you are doing.
                          As none of the above is relevant to any of us its all difficult.
