Centec 2A milling machine horizontal / vertical mill.
Home › Forums › Manual machine tools › Centec 2A milling machine horizontal / vertical mill.
  • #826939
    howardb
      @howardb
      Found this when looking on RDG’s web shop for something else.
      I understand that they were highly regarded and versatile being horizontal/vertical capable.
      *Clearance / end of line stock*
      Centec 2A milling machine horizontal / vertical on cabinet 2mt head
      £1,625.00 (exc VAT) – £1,950.00 (inc VAT)
      #826952
      Dave Halford
        @davehalford22513
        I’m rich!!!!
        #826967
        Andrew Tinsley
          @andrewtinsley63637
          Add in the delivery charge and it is a bargain.
          Andrew.
          #826980
          Nigel Graham 2
            @nigelgraham2
            Even more so if with the Raising Block, a long casting with dovetails top and bottom to raise the ram by about three inches.
            They are good machines though.
            #826994
            noel shelley
              @noelshelley55608
              Is it new ? Remember it’s a 2A not the 2B.
              #826995
              duncan webster 1
                @duncanwebster1
                2B has better table traverse
                #827002
                not done it yet
                  @notdoneityet
                  It does have a riser block, but a short one (probably CI or steel?) – but does not appear to have any parts for horizontal operation.
                  As Dave says, it makes a 2B look valuable  Especially with the long ally riser (made by Gary), power feed (on the long travel) and three phase motor with VFD.
                  #827015
                  Nigel Graham 2
                    @nigelgraham2
                    The riser block needs be only the length of the top of the column.
                    I don’t think it would be too difficult to find a suitable arbor, nor to make a drop-bracket for it. I had to do that for a Centec I owned for a while.
                    To finish-bore the bearing hole to size and alignment I clamped it rigidly to the table with an angle-plate, slackened the ram clamps and fed the lot inwards against a boring-head.
                    A 3ph conversion? Maybe nice to have but not really essential.
                    #827047
                    not done it yet
                      @notdoneityet
                      Agreed, the normal short riser (like the one advertised) is all that is needed, but the long riser can allow horizontal operation without removal of the vertical head.
                      I don’t think three phase “conversion” was mentioned?  Many machines were supplied with 3 phase motors and later “converted” to single phase.
                      A 3 phase drive is far better (IMO) than the single phase on that machine.  Variable table feed rate and a smoother motor, with less vibration (there were issues with induced vibrations within the stands with single phase machines) must mean an improvement elsewhere.  I know which I prefer.
                      #827126
                      Nigel Graham 2
                        @nigelgraham2
                        I did indeed notice the immediate improvement when I changed the original single-phase motor on my Myford lathe to 3ph, and I have treated my Myford milling-machine and Harrison lathe (all elderly 2nd-hand machines) similarly, but for a relatively small machine-tool it’s not an absolute priority.
                        My Centec had a 1ph motor and it ran perfectly well, whatever may have been on it originally.
                        What I think matters more in this case is restoring its horizontal-milling ability.
                        #827127
                        Michael Callaghan
                          @michaelcallaghan68621
                          Having owned a centec milling machine, yes they take up little space. However they are very limited in what they can machine. For the money there are far better machines available. I paid £500 for mine with the rising block and lots of extras, and that was only two years ago. Sold it for the same money after needing more bed space, and power.
                          #827128
                          duncan webster 1
                            @duncanwebster1
                            A single phase motor mounted in the cabinet makes it very noisy, the sides vibrate (don’t ask how I know). This one has timber bolted in to try to mitigate it. When the centrifugal switch on my single phase motor died (they don’t like being switched on and off all the time) I switched mine to a 3 phase motor the change was dramatic.
                            #827172
                            Michael Callaghan
                              Duncan, I found that drilling two holes in the cabinet sides and then passing some 10mm threaded bar through the holes and then adding nuts and washers and compressing the cabinet sides a bit put an end to the noise issue.
                              #827205
                              Nigel Graham 2
                                @nigelgraham2
                                That was the first happy discovery with “three-phasing” my Myford lathe: no more very loud cabinet resonance; but the cabinet is of folded sheet-steel so quite likely to vibrate.
                                I am slowly recommissioning an ancient Denbigh horizontal mill not much larger than the Centec B, and decided it was not worth a lot of ££ for three-phase drive for an old horizontal-only machine on a massive cast-iron stand, and with a spindle speed somewhere around 70rpm.
