Calculation of tube heating area
Home › Forums › General Questions › Calculation of tube heating area
  • #23094
    Geoff Stevenson
      @geoffstevenson56049
      #141427
      Geoff Stevenson
        Would anyone have the formula, or better still, know how much heating area would be provided by a fire tube 8 inches long by 1/2 inch bore diameter.?
        Many thanks.. Geoff.
        #141429
        GoCreate
          @gocreate
          Hi Goeff
          circumference x length = PI x bore x length
          3.142 x 0.5 x 8 = 12.568 sq ins
          Nigel
          #141435
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Geoff ,
            On earlier question of engine HP – look in pm’s .
            Regards ,
            MikeW
            #141437
            jason udall
              @jasonudall57142
              Nigel …
              Don’t disagree with maths
              But shouldn’t that be the OD of pipe…
              And should that be derated some ( ahh just by how much)
              Beacause of shadowing from adjacent pipes…or itself..depending on heat source…
              #141443
              MICHAEL WILLIAMS
                Jason ,
                Nigel’s calc is correct and uses the id as per conventional practice .
                You raise an interesting point though . The spacing of tubes has an important influence on effective heating area .
                Too far apart and you waste potential heating area in that you could have more tubes in the same space .
                Too close and water can’t circulate properly between tubes and both effective heating area is reduced and there is danger of burnout .
                Some full size boiler designs use a simple rule based on 1/2 or 2/3 tube diameter water spaces between tubes .
                Some of ‘LBSC”s boilers are awful as regards tube spacing – he always had as many as possible regardless of whether there was adequate spacing and on a few at least regardless of whether they would even fit in the boiler !
                Regards ,
                MikeW
                #141537
                Geoff Stevenson
                  Thank you gentlemen. I had very roughly worked this out by regarding the tube as being flat and multiplying the circumference (width) by height.. the width (circumference) of 1/2 inch bore is about 1 1/2 inches. 1.5 x 8 = 12. Seemed too simple to be true so I am grateful for the confirmation. The tips on spacing will be helpful too. I was going to allow a tube width spacing but I may amend that. Thank you and best wishes.. Geoff.
                  #141559
                  julian atkins
                    @julianatkins58923
                    hi geoff,
                    i dont know what you are building but on a miniature loco there are lots of other factors to be considered such as the free gas flow area as a percentage of the grate area, the keiller proportions, and the late jim ewin's findings that only say the first 1/3rd length of the tubes provide any heat transfer.
                    cheers,
                    julian
