following on from my other thread, I may need to make a new shaft for the gearbox, the drill is a 2 speed job with a crash gearbox affair….
The shaft that emerges from the gear box carries the chuck and runs at the front in a 6200 bearing, supported at the rear with a nr bearing. The shaft carries the spur gear for the 2 speeds….the spur gear has a pb bush in the midle so it rides up/down the shaft as required…
So my question is what grade of steel is needed for a new shaft?
I'm guessing EN1 is going to be too soft…?
