Brass Studding
Brass Studding
Home › Forums › General Questions › Brass Studding
  • #141164
    Steam Models
      @steammodels
      Hi Everyone
      I am trying to find 3/16 x 40tpi brass studding for a project I'm currently working on. I have tried all the usual places but have had no success yet. I would be very grateful if anyone could tell me where I might get some, I would like 12" of it ideally.
      Many Thanks
      David
      #23086
      Steam Models
        @steammodels
        #141168
        Saxalby
          @saxalby
          I have never seen ME thread studding.
          What is the project that specifically requires this size. 2BA studding is available, very slightly smaller and approx 32 TPI. Would that not suffice.
          Barry
          #141178
          Steam Models
            @steammodels
            Hi Barry
            Thanks for your reply. Unfortunately this is too small. The project is a carburetor for a Westbury Internal Combustion Engine so it needs to be this size. This is already tapped for this size.
            Thanks
            David
            #141179
            John Billard
              @johnbillard11913
              Surely it would not be too difficult to make? I presume that a whole 12 inch length is not needed?
              Best wishes
              John B
              #141190
                Given the cost of brass studding in the BA sizes its likely to be cheaper to buy a length of 3/16 brass and a die thats if you could even find it in 3/16 x 40
                Does it need to be threaded all the way? most studs just need threading each end.
                J
                #141220
                Sub Mandrel
                  @submandrel
                  in brass its a size that's nice and easy to screwcut as well.
                  nigel jones 5
                    @nigeljones5
                    Joe at maccmodels sells studding – but as above, its a load cheaper to buy bar and a die
                    #141400
                    David Clark 13
                      @davidclark13
                      Buy a 40TPI Coventry die set from Ebay or Tracy Tools and screwcut it.
                      regards David
                      #141411
                      julian atkins
                        @julianatkins58923
                        why would you spent a relatively large sum on a coventry die head to thread some 3/16" brass bar?
                        (unless youve just won the lottery!)
                        a tailstock dieholder with a hole drilled through it for the material will do perfectly ok for 3/16" x 40 tpi. i have a lever tailstock on my lathe which assists things a bit, but it would be a few minutes work to thread same as described on most lathes. never had any 'run out' on the thread. ive quite often cut ME threads this way in the lathe in brass and bronze
                        cheers,
                        julian
                        Edited By julian atkins on 22/01/2014 22:24:17
                        #141416
                        Nobby
                          @nobby
                          Hi David
                          Why not screw cut . I cut 5/32 whit over about 7"travelling steady" on my S7 Mk one Using a traveling steady
                          Regards Nobby
                          Edited By Nobby on 22/01/2014 22:31:29
                          Edited By Nobby on 22/01/2014 22:32:04
                          #141430
                            Julian, DC1 suggested a die set not the whole head, you use one of the cutters as your form tool and screwcut with that. I think Tracy even do a special holder for them.
                            J
                            #142178
                            Steam Models
                              @steammodels
                              Thank you everyone for your suggestions. I had tried threading the bar myself, but for some reason the threads proved too loose. I managed to track down a supplier that carry this size, BA Bolts.
