I have a Boxford 280 lathe. I have recently been tuning out all the play and trying to adjust everything to optimum.
I recently acquired a nice Burnard collet chuck but when I fitted I had around 6 thou run out at the work piece.
I removed the chuck from the back plate and checked the register and still had run out.
I then removed the back plate from the spindle and checked the spindle itself.
I have about 2 thou run out on the face of the spindle (first picture) but none the inside edge of the spindle (second picture) which tells me the spindle is not bent.
I have created an album with pictures of what I am trying to describe.
Now I could machine the face square, but if that is the correct thing to do then I would have expected this to have already been done sometime in the 30+ years since this left the factory.
The nose and spindle appear not to be one piece but I can see no way of removal or adjustment bar total removal of the spindle itself which I am keen to avoid.
Any suggestions?
Thanks in advance.
Edited By Gavlar on 22/06/2020 11:51:36
Edited By Gavlar on 22/06/2020 11:59:13
