Boiler hydraulic test
Home Forums General Questions Boiler hydraulic test
  • #506452
    Kevin Bennett
      @kevinbennett25223
      Hi Guys i have Finished brazing my 5" Tich boiler i am doing my first hydraulic test to see if it leaks i know it runs at 80 PSI and times 2 = 120 PSI test but how long has the test got to be in hours / days
      also i know i have proper test with wa qualified inspector
      Thanks Kevin
      #27765
      Kevin Bennett
        @kevinbennett25223
        Hydraulic test
        #506453
        Jim Nic
          @jimnic
          Hi Kevin
          First revisit your sums and/or typing skills. wink
          80 psi times 2 = 160.
          Other than that I regret I have no useful information to offer.
          Jim
          #506454
          Kevin Bennett
            @kevinbennett25223
            opps missed that
            #506458
            Roger Clark
              @rogerclark
              I would suggest taking to 50psi, rest for 10 mins, if no pressure drop then up to 80, rest for 5 mins, if no pressure drop then increase in 30psi increments check for drops until you reach max pressure.
              Others will probably differ devil
              Roger
              typos!
              Edited By Rockingdodge on 10/11/2020 14:51:04
              #506462
                Page 17 of the test code
                #506471
                Kevin Bennett
                  @kevinbennett25223
                  thanks for that information i can now move on with it
                  #506540
                  Dave Halford
                    @davehalford22513
                    Don't go over 160 !
                    You should really try 15psi of air first just in case there's a seam not done.
                    #506542
                    duncan webster 1
                      @duncanwebster1
                      I made a fitting to fit to a bike pump to put a LOW pressure of air in. If you can't get it to hold low pressure air don't waste your time with hydraulic. If it holds low pressure don't be tempted to go for high pressure air, go for the hydraulic
                      #506546
                      Dave Smith 14
                        @davesmith14
                        Kevin
                        Good luck with your hydraulic. For those of us about to or actually building a boiler anything you have learnt along the way that would be useful to share?
