Bevel gears.
Bevel gears.
Home › Forums › General Questions › Bevel gears.
  • #447555
    wendy jackson
      @wendyjackson
      hi chaps, today I took out a battery locomotive I am trying to sort out. I have fitted a 750w motor which works well. However the old bevel gears which look like they came from an old hand drill make a lot of noise and have a lot of wear. Can anyone please let me know of a company that I can purchase new gears from. Also is it normal for bevel gears to make a sort of rumble noise when in use, which is a bit to noisy for my liking. Thanks
      #27084
      wendy jackson
        @wendyjackson
        #447560
        larry phelan 1
          @larryphelan1
          I think I saw such gears offered by a supplier called Belts-on-line.
          They offered all sorts of gears in many different sizes.
          Might be worth a try.
          #447574
            It's actually belting online they are quite reasonably priced and gears will be fine for your use.
            #447594
            not done it yet
              @notdoneityet
              Another that might be worth checking out?
              HPC Gears.   **LINK**
              Edited By not done it yet on 19/01/2020 17:25:53
              #447596
                Posted by terry callaghan on 19/01/2020 15:20:45:
                Depending on size, replacement angle grinder ones are helical bevel gears and stupidly cheap, and although most angle grinders 'shriek' they are pretty quiet at loco-driving speeds.
                noel shelley
                  @noelshelley55608
                  Duval stock gears ! A vast stock. Noel
                  #447786
                  larry phelan 1
                    @larryphelan1
                    Thank you Jason, I stand corrected ! and you are right, they are quite good for price and range.
