Anecdotes_05 ‘ In the dark ‘
Home › Forums › General Questions › Anecdotes_05 ‘ In the dark ‘
Viewing 25 posts - 26 through 50 (of 50 total)
  • #144210
    jason udall
      @jasonudall57142
      Many years( or atleast pre 1980)
      In eprom memory chips an unexpectedly high data corruption rate was noticed. ..to track this down a batch of wafers was bonded out ( wired using very thin gold wires) for test purposes….batch A some other wafers were processed normally. .split up to be later..encased ..bonded out
      Then this batch was was split in two futher groups one encased as normal in ceramic with little quartz window..and the rest encased in expoxy as most silicon chips are…
      The in effect same chips were tested. .uncased..ok
      Plastic case ok…
      Ceramic…failing
      It was all traced to radio active minerals in the clay of the ceramic…
      Its every where. .
      Edited By jason udall on 17/02/2014 12:30:01
      #144215
      Swarf, Mostly!
        @swarfmostly
        Posted by MICHAEL WILLIAMS on 17/02/2014 11:36:29:
        Hi Ian ,
        SNIP
        Coal isn't the worst offender though – some of the Cornish Tin/Lead/Arsenic/etc mines had very high levels of radioactivity as did some Granite quarries .
        SNIP
        Regards ,
        Michael Williams .
        One of the minerals found in the Cornish mines was/is pitchblende, aka uranium ore. It was mined and supplied to glass manufacturers. Despite its black colour (hence the name) it colours the glass a dense yellow.
        Best regards,
        Swarf, Mostly!
        #144216
        jason udall
          @jasonudall57142
          Seem to remember pitchblend also contains radium…
          And granite is a known source of radon ( nasty since its a gas and really easy to get into the body)..so any mine in granite is fun.
          #144228
          Bubble
            @bubble
            Hello all
            In the 1950's, astronaut John Glenn experienced a total lack of instrument illumination when flying a fighter at night, over the sea during the Korean war. He found the aircraft carrier by following phosphorescence from the carrier's prop.wash for several hundred miles, and landed safely.
            Jim
            #144256
              Radon – in some parts of the UK houses over granite have to have extractor fans in their cellars to prevent build up of radon.
              OuBallie
                @ouballie
                IanP & Martin,
                I will let this run for a while as I love a mystery.
                All this talk of going into the bowels of the earth reminds me of the time in the Cango Caves near Oudtshoorrn, and the lights being turned off to let us have the experience. The total & utter blackness sudden was not a little daunting at first, but it didn't last long enough for us to experience any peripheral light. Quite an experience though, as well as going through those caves.
                Another memorable one was going down the deepest mine in the world, namely Western Deep Levels near Carletonville, and having the heat and humidity hit you like a brick wall.
                Geoff – All that took place 50odd years ago. Where the blue blazes has that time gone?
                #144298
                Ian S C
                  @iansc
                  Radon is widely found on the West Coast of the South Island of NZ, there is a large area of minable Uranium in the area, it is also very rich in high quality coal.
                  About 45 years ago, Kodak, and others had to stop using paper to separate X- ray film (it used to be yellow), it was found to contain enough radiation to fog the film in increasingly shorter and shorter time, this was about the time when trees were maturing after the first of the atomic bomb tests, and the Japanese bombs. Ian S C
                  #144335
                  jason udall
                    @jasonudall57142
                    Apparently. . Steels made pre ww2 ( well nuclear)..are sort after since they don’t have radio isotopes (odd sure there would be before but maybe much less)….
                    #144338
                    Billy Mills
                      @billymills
                      Before fast digitization and storage came along fast events were recorded on oscilloscopes with fast photographic film. One off events gave too little light to record on film so "pre-fogging" was used, a very low level light exposed the film so that less light was needed to record the scope trace. Tektronix then built a multichannel electron multiplier into their crt's so that the apparent intensity on the screen could be increased by 1,000 to 10,000 times. This enabled recording one off experiments that were impossible to repeat such as atomic weapons testing. There is a very good museum devoted to atomic testing in Los Vegas, they have very knowledgable staff who really know their atomic physics and instrumentation, just downwind from the Nevada test site.
                      The multichannel multiplier is now used in some image intensifiers.
                      X-ray film was very expensive, it had a thick silver containing emulsion, nowdays silicon sensors replace the film, more sensitive, no storage issues and no development needed, the image is produced immediatly and the radiation dose is much smaller.
                      Billy.
                      #144481
                      MICHAEL WILLIAMS
                        @michaelwilliams41215
                        Not quite the same topic but related I think :
                        Back in March last year I had an aged mother in hospital and I had to make a couple of emergency visits in the dead of night .
                        The hospital is located right on top of one of the highest hills around and away from the majority of domestic housing .
                        Anyway it was sparkling clear frosty weather when I came out one night at about 3am .
                        The canopy of stars was magnificent that night – thousands of them and all the main systems and single stars and planets could be clearly seen .
                        Where I live lower down the same hill and amongst many houses I am lucky to see twenty stars at night – the ambient light level is now so high .
                        The difference in altitude , clearer air and much lower light levels at the hospital level made all that much difference .
                        Living in the country as a child I used to see all the stars on most clear nights but now it’s become a rare treat .
                        Other good memories of seeing the full star canopy in UK are from Cefn Bryn , from Clifton down and from Salisbury plain .
                        A memorable location from abroad was when I lived in Bavaria and saw the stars over the mountains .
                        Incidentally looking down hill from the hospital and back into the central city area I was almost blinded by the light levels – I couldn’t conjecture how many Giga Watts of electric power were being dissipated uselessly that night .
                        Michael Williams .
                        Edited By MICHAEL WILLIAMS on 20/02/2014 00:13:16
                        #144498
                        Billy Mills
                          @billymills
                          Locally street lighting goes off between midnight and 6 am as an energy saving measure so the sky change is very apparent. In some areas the street lighting electricity is not separately metered, they are charged on the number of lights, estimated consumption and hours on, it's too expensive to wire up metering.
                          Some towns have a "dark skys" policy, street lighting is directed downwards and of limited power so the stars appear against a velvety black background. When you are getting near some towns at night you can see a foggy dome of light enveloping the town, light spill upwards illuminating dust and mist in the air.
                          With most people city dwellers they don't get to see a starry dark sky, just a dim fog with a few stars. There are only a few places in the UK where the skys are really dark as you need to be perhaps 20-30 miles from urban areas.
                          One real weird UK lighting madness is that local councils light side roads with no cars per hour and people inside buildings but very busy Motorways -such as the M25 and A1M – have no lighting in many places.
                          Billy.
                          #144508
                          Bazyle
                            @bazyle
                            Posted by Billy Mills on 20/02/2014 09:43:46:
                            Billy.
                            This is safety and security in side roads which is very welcome to women especially. In my home village there is just the one streetlight which makes us very 'grown up' like a real town. Elsewhere in the village a torch or wellies is essential becasue the cattle sheep and horses have free reign ……….frown
                            #144601
                            daveb
                              @daveb17630
                              Posted by jason udall on 18/02/2014 18:01:24:
                              Apparently. . Steels made pre ww2 ( well nuclear)..are sort after since they don't have radio isotopes (odd sure there would be before but maybe much less)….
                              Something similar is low alpha lead, one source of this appears to be sunken ships.
                              #144607
                              MICHAEL WILLIAMS
                                OuBallie ,
                                Ambiguous word since different spellings of the Ballie bit could have different meanings in different languages but given your occassional mentions of S.Africa is this anything close :
                                Afrikaans for any of father figure , mentor , guardian , family elder – basically same as ‘The Old Man ‘ in English .
                                Probably semi slang coming from Dutch/German .
                                Regards ,
                                Michael Williams .
                                #144609
                                MICHAEL WILLIAMS
                                  I’ve heard that stars can sometimes be seen more clearly in poor viewing conditions from the bottom of a deep shaft such as a mine (or well) .
                                  Coalmine shafts visited have been too cluttered at the top with pit head gear to see much so I can’t say whether it’s true or not .
                                  Michael Williams .
                                  #144632
                                  Billy Mills
                                    @billymills
                                    Would sugest that wells and mines could give a better view because only a small part of the sky glow ( from street lighting) would be visible so after a while in real darkness ( with the mine lights off) the human eye would reach high sensitivity. Urban Canyons might not work as well because most buildings loose a lot of heat so there is a lot of thermal turbulance as well as a bright sky and local lighting to contend with.
                                    Some astronomy is done through optical filters which reduce the brightness of the sodium d lines ( the bright yellow ones), that helps quite a bit. The eye is quite sensitive to yellow however if you take a picture under sodium streetlighting it is mostly red.
                                    Perhaps one of the most strange aspects of the human eye and vision is that the retina is not a continuous light sensitive surface, it is covered with many blood vessels yet when we are awake we normally experience no trace that our eyes are not so perfect. Sometimes when you wake in the morning or when you are at the opticians you might glimpse the blood vessels tree trunk appearance but it then dissapears in a flash as it is " computed" out of our perceived vision.
                                    Billy.
                                    #144635
                                    Bill Pudney
                                      @billpudney37759
                                      When I had to work for a living, at one stage I worked near Edinburgh RAAF base, on the Northern outskirts of Adelaide. RAAF Edinburgh was used as a sort of "base camp" during the nuclear bomb trials (at Woomera) in the 50s. Being an electronics/avionics/defence industry sort of place we used to get a lot of bright eyed, bushy tailed young electronics Engineers.
                                      One evening whilst working late I went to the tea room to make a coffee. Already there was a young Engineer, looking confused. Pointing at the water tap he asked if the water was safe to drink. I said, "….well you will have heard about the nuclear tests, when they used to fly the aircraft through the mushroom cloud? They flew back to the RAAF base and washed the fallout off of the aircraft. The wash water went into the groundwater, which is what comes out of the tap. Some people say that if you use a glass cup, full of water, on a dark night, you can use it to light your way." At this point the young Engineer went pale, emptied his cup down the sink and left.
                                      cheers
                                      Bill
                                      Edited By Bill Pudney on 22/02/2014 01:45:13
                                      #144638
                                      Ian S C
                                        @iansc
                                        I'v not tried it, but it is said that you can, given a clear sky, see the stars in day light from the bottom of a deep shaft/well. Ian S C
                                        #144646
                                        Gordon W
                                          @gordonw
                                          Yes, Ian, true, so long as the sun is not to near of course.
                                          #144675
                                            Party pooper: **LINK**
                                            Gordon W
                                              @gordonw
                                              Maybe, but I wasn't looking thru' a cardboard roll, was at bottom of a 90 ft. pot and it was fairly late in late winter. Maybe was snowflakes.
                                              #144934
                                              OuBallie
                                                @ouballie
                                                Posted by MICHAEL WILLIAMS on 21/02/2014 19:31:32:
                                                OuBallie ,
                                                Afrikaans for any of father figure , mentor , guardian , family elder – basically same as 'The Old Man ' in English .
                                                Regards ,
                                                Michael Williams .
                                                Top marks for your homework!
                                                Ouballie means 'Old Man' in Afrikaans slang, and I'm certainly in that category, being three score and ten later this year.
                                                I do remember, when in in my 20s, wondering if I would see the Millenuim in! At that age of course, anyone over 35 was well past it, and no doubt the same thoughts by the young turks today.
                                                The light I HAVE seen is that things now take forever to do.
                                                Geoff – Still semi-floored from treatment, but improving.
                                                #144937
                                                Ian P
                                                  @ianp
                                                  Thanks for clearing that up Geoff even if I had to wait because YOU like a puzzlesmiley.
                                                  Ian P
                                                  #144942
                                                  Gordon W
                                                    @gordonw
                                                    " In the dark" ,Maybe this could be combined with the Wills post?
                                                    #145074
                                                    OuBallie
                                                      @ouballie
                                                      Posted by Ian Phillips on 24/02/2014 15:35:59:
                                                      Ian P
                                                      Patience oke, patience, as in virtue
                                                      Geoff – Sidetracked into roasting coffee now.
                                                      Edited By OuBallie on 25/02/2014 14:21:09
