All things Beaver Mill
Home Forums Manual machine tools All things Beaver Mill
Viewing 25 posts - 126 through 150 (of 229 total)
  • #535151
    Mark Guy
      @markguy26995
      Hi Brian I’ve added another 5 photos of the lead screw if they are of any help
      #535186
      Peter_H
        @peter_h
        The MkII has a shear pin on one of the leadscrews. I can now see why!
        #545109
        Jonathan Deen
          @jonathandeen39055
          Don't suppose anyone here could email me a pdf manual & parts diagrams? Recently picked up a mk2 vbrp that suffers from a seized quill. (Previous owner left the poor thing outside). Would be helpful when i strip the back gear gearbox as I suspect their may be some moisture lurking within
          [email protected]
          Cheers.
          #545168
          DC31k
            @dc31k
            Posted by Jonathan Deen on 14/05/2021 23:14:42:
            https://onedrive.live.com/?cid=547FE296ECFD561F&id=547FE296ECFD561F%211426&parId=547FE296ECFD561F%21189&o=OneUp
            #545300
            Peter_H
              @peter_h
              You seem to already have a huge number of manuals. Do you get bored with machines quickly and have to change them often?
              #545563
              Jonathan Deen
                @jonathandeen39055
                Posted by DC31k on 15/05/2021 10:39:17:
                Very much appreciated, will certainly help get the mill back to working order
                #561275
                Mark Walker 7
                  @markwalker7
                  Hi all. I have a beaver mill mk5. It is fully working as a manual machine but it has a Anilam 3000m cnc control fitted but I am having problems with it. The machine has an air operation quick change tool holder. What I am looking for is some of the mounting fittings for the top of the tooling. Dose anyone have any for sale or know where I can get some.
                  thanks
                  mark
                  #561305
                  DC31k
                    @dc31k
                    Posted by Mark Walker 7 on 04/09/2021 21:23:15:
                    They are called a 'pull stud'.
                    Put 'Beaver pull stud' into Google.
                    You will find:
                    https://www.practicalmachinist.com/vb/general/beaver-nc5-pull-stud-dimensions-153752/
                    Mr Hood is on the mig welding forum if you need to ask him further questions.
                    https://spares.xyzmachinetools.com/Special-Pull-Studs-40-Beaver-V5Nc5/product/4829/79931-010/
                    https://www.madmodder.net/index.php?topic=12928.0
                    Reading the above, it seems there may be two types, for earlier and later machines, so check well before spending.
                    #572078
                    Craig Marshall
                      @craigmarshall51970
                      Hi all – I am also new to the group. I have a beaver PAL mill which has no back gear, and the all-belt head. The rear layshaft in the head is pressed into the eccentric (for tightening the belt), the pulley set is then riding on two LS9 bearings on that shaft, according to the drawings. The pulley set can't come out through the top of the head casting, so I'm wondering how to disassemble this thing? Mine has got quite noisy, so I'd like to replace those bearings.
                      Also – I have a fair amount of wear on my splines I can see comparing the unworn area to the worn area that the lands are almost a millimetre narrower. Are there any other options than the one shown earlier in this thread? The wear is worst at the bottom (quill retracted), and lessens as you go up (quill projected). So any kind of backlash limiter is only going to work at one point.
                      Thanks,
                      Craig
                      #572394
                      Mark Rand
                        @markrand96270
                        I've never seen a PAL head in real life, only the drawings in the assorted manuals that Tony's lathe site has got. I'm guessing that one has to get the centre pulley and motor out of the way, followed by the spindle pulley and its bits, then unbolt the rear pulley from its shaft, remove the shaft and eccentric out of the top and finally manoeuvre the rear pulley through the front part of the side door holes.
                        It will come out, since they got it in, but there is probably a way that works and many ways that don't. The Mk1 head has got a definite knack to assembling it as well, but after the first half dozen times it becomes intuitive!
                        As to the splines, is it the spindle splines that show the wear or the drive bush's internal splines? In either case one might need to make a new drive bush, but in the former case, one would need to either make a new spindle or use a surface grinder, shaper or mill to cut back the good parts of the spindle splines until they were thinner, but all the same width. Then send both bits off for heat treating.
                        A spring loaded backlash eliminator might work, but one would need to find space for it, possibly by making a spacer plate between the head and the pulley box.
                        #572605
                        Peter_H
                          @peter_h
                          Same problem with my MK2 VBRP Beaver mill. The splines rattle like a good 'un but I couldn't tell you which pair it is that have the worst play. I got all the bearings, etc to tilt the head over 90 deg, get the spindle out and start going through it to see if there is anything I can do about. it's now a couple of years later, I'm much closer to 70 and feeling less an less able to tackle it (
                          #581116
                          Ian Bowers
                            @ianbowers85137
                            Well after a bit of time effort and money my VBRP is about quiet, I replaced all of the spindle bearings and the two large bearings that support the back gear shaft, I think these were the noisy ones. I also managed to get a better spline mesh by facing off the drive side splines so it meshed deeper. I spaced the toothed pulley down by a similar amount to keep everything level.
                            So it’s about rattle free and not much other noise for once! I’ve replaced my of singe phase motor with a new 3 phase motor and new VFD along with a 3 phase feed motor and VFD.
                            so it’s ready for another 50 years!
                            #581420
                            Ian Bowers
                              @ianbowers85137
                              After a bit of use the feed gearbox is still noisy , but how do you take it off easily? The motor is off and I have removed the two screws on the front (on the right side) and the four screws on the back (left side). The back will come off a couple of mm until it hits the cross slide nut assembly, this is difficult to remove as it has dowels in it preventing it sliding along out of the way.
                              The main box will come out about 1mm then I think some gears are starting to catch on something, so is the answer to take off the table?
                              thanks Ian
                              #581433
                              Mark Rand
                                @markrand96270
                                With the Mk1 gearbox:-
                                You need to take the table off to remove a couple of other screws on the top of the gearbox that you can't get at with the table on:-
                                I can't remember if you also need to remove the left/right clutch fork shaft as well to get at one of the screws Probably not.
                                After that, the gearbox will come off complete and you can get the back off it.
                                Edited By Mark Rand on 20/01/2022 19:36:40
                                #581458
                                Ian Bowers
                                  @ianbowers85137
                                  Thanks Mark, it’s all apart now, I think I will get away with some new bushes, the one on the input shaft is nicely worn.
                                  The worm and wheel look ok I’ll just remove a few sharp edges.
                                  ian
                                  #581513
                                  Peter_H
                                    @peter_h
                                    Ian,
                                    That sounds very interesting. Do you have any sketches or dimensions and references to the part diagrams please?. If there's a short cut to getting rid of some of the spline rattle I'm up for it, but I don't quite follow what you've done. Thanks.
                                    #581518
                                    Ian Bowers
                                      @ianbowers85137
                                      Hi Peter the way I reduced the play in the coupling was to get it to go together further so the tapered dogs were touching on the sides fully. I machined of the tops o the dogs so they were not bottoming out but were touching on the sides.
                                      to ensure the toothed pulley was in the same place and to ensure the back gear would come up far enough the mesh properly I made a spacer to space the shaft back to where it was.
                                      The photo below shows it half done.
                                      #581520
                                      Ian Bowers
                                        @ianbowers85137
                                        #581610
                                        Peter_H
                                          @peter_h
                                          Ahhh.. tapered dogs. Now it makes sense. I assume the big gear is the back gear – I have that. Unfortunately the rest of it doesn't ring any bells. Maybe we are different versions. Mine is the VBRP MkII with the variable ratio taper belt drive up the top. My back gear drop int to engagement by manual lever. The gear is fitted on a hollow shaft with dogs, but they have more teeth than that. I did a section drawing in Qcad which is in one of my picture albums here. I will investigate further, as if the trimmed tape dogs ahs relevance here I can't wait to get it done!.
                                          #582916
                                          Harold Jolly
                                            @haroldjolly73409
                                             the threads are no good20220102_164016.jpg20211227_163552.jpg I need help with the leadscrew on the table. Like to know if anyone can help. Here are a few pictures showing the nut.
                                            What type of material would you think to use?
                                            Edited By Harold Jolly on 29/01/2022 14:25:16
                                            #582921
                                            Harold Jolly
                                              @haroldjolly73409
                                              sorry about all the pic are turn . I do not know how to fix it.
                                              #582949
                                              Mark Rand
                                                @markrand96270
                                                Use cast iron, the same as the original. Then make sure that it is lubricated with oil, not grease.
                                                It's far more easy to replace a pair of cast iron feed nuts than to replace the feedscrew after bronze nuts have worn it. It's a pity that Bridgeport never learned that lesson…
                                                Here is one that I made earlier. I had to do it again because I made the outside diameter 0.003" too small. crying
                                                Edited By Mark Rand on 29/01/2022 19:15:58
                                                #582987
                                                Harold Jolly
                                                  @haroldjolly73409
                                                  Thanks Mark for sharing >where did you buy the material?
                                                  #582997
                                                  Mark Rand
                                                    @markrand96270
                                                    It was some continuously cast bar that I'd had for a number of years. I'd bought it from a steel stockholder in Birmingham.
                                                    metals4u.co.uk stock it in small and large quantities (use the search feature, it isn't listed in the menus).
                                                    m-machine.co.uk have it in their catalogue by the inch
                                                    http://www.steelexpress.co.uk have it, but need to be phoned or emailed (very good for tool steels and specialist stuff)
                                                    College engineering seem to have gone off with the fairies after mum and dad retired
                                                    there are some sellers on ebay, they often claim it as being Meehanite, but Meehanite is a specific set of licensed processes.
                                                    There are probably plenty more, but those are ones I've dealt with.
                                                    #583926
                                                    Harold Jolly
                                                      @haroldjolly73409
                                                      Would it be possible to bye it from you ?
