Gas Tap Valves. Vintage
Home Forums Related Hobbies including Vehicle Restoration Gas Tap Valves. Vintage
Viewing 25 posts - 1 through 25 (of 48 total)
  • #852613
    dee
      @dee
      Hi, I’m new here so please bear with me. I thought this should perhaps be be under Help of Assistance, but though it best to start here.
      Vintage three ring burner.
      Gas Tap Valves.
      I’ll get right into it…
      The valve barrels with their tapered tap valves, are what I’m looking to find a solution for. One of these had snapped off at the valve bracket. Fortunately, knowing a few folk in the business, some friends were able to machine up a replacement brass barrel in their spare time. Fitting the existing male taper ‘key’ valve to the new female taper has been the challenge. That part is machined, I’m now looking to find how to get the tolerances of the whole tapered valve/s to slip fit perfectly.
      The construction of the valve is a brass barrel with a tapered hole into which the male tapered ‘key’ valve fits to create a gas tight fit. This is operated between on and off through a 90˚motion. This ‘key’ valve is held in place with a UNF1/4 thread, a tag washer, a spring washer and captive nut.
      A 1/15 ratio reamer taper which is a taper of approximately 3.8˚ from the axis, was used to form the new barrel taper, but these are approximations that I do not have the metrology to attain exactitude, and have yet to find how to make the slight discrepancy of taper angles between old and new, slip fit to tolerance. I have tried various specialist gas related sealers/ lubricants and tapes which have improved matters, but a tiny amount of play is still present.
      Forming ideas for the slip fit went as follows: some lapping paste, maybe >400grit, but the thinking was that that would ultimately deform the planes of both conical tapers, abrading the old as well as the new, deforming the original reference. On to the next idea!
      The next idea was to temporarily glue (with bearing retainer) emery paper to the ‘key’ tapers which are original and in good condition, having no light coming through on a flat test of their planes, these could be ‘former’ to the newly machined barrel taper. The difficulty was that emery paper could not be gotten thin enough to reach the lower, narrowest part of the new barrel taper hole in that arrangement. This re-profiling using the ‘former’ idea was done by hand, concentricity was a concern, but after several sessions of minute material removal, this did make a difference improving matters. Once assembled the leaks had reduced to small ‘buds’ when ignited, but not gas tight, and as you might conclude, that’s not acceptable. The relative height of the key tapers in operating situ and making these tapers deeper or altering the original ‘key’ tapers in any way did not seem wise, so the project was shelved.
      The narrow taper ø is 8.9mm probably aiming for 11/32″, the wider taper ø is 10.4mm engineered for 13/32″ across 1/2″
      My lack of equipment to accurately measure and then hone (if thats the right word) very particular conical taper angles is the challenge. With the right equipment, it’s a twenty minute task for three valves.
      A full length male taper without the hole of the original, with the exact same angle with an even abrasive applied that could fit in a chuck, was as far as my thinking got.
      This is the last hurdle on the restoration, which I would really like this not to become a door stop!
      So here I am, hopping to impress upon some one with more experience than my self what the solution may be to getting these taper valves gas tight?
      This is what it looks like:
      A
      General assembly:
      Frame 18″ cast
      Burner, cast
      Valve bracket, cast
      Valve barrels, brass
      B
      Foundry Logo?, manufacturer unknown
      C
      As you can see most of the work is done, it’s no longer a ball of orange rust. It now stands. It blows clear, it has valves and all leaks have been identified and sealed with the correct compounds.
      D
      E
      F
      This is the new valve internal that requires a slight internal re-profiling as mentioned above:
      G
      The air intake/ oxygen mix adjusters are quite loose due to being thin, I think 1/6″ from memory, they have a habit of rusting up.
      They could do with being 1/8′ thick in brass with a interference fit for stability, this would complete the refit.
      #852614
      Diogenes
        @diogenes
        EDIT – aha, now there are pictures – not sure how useful the info below will be..
        Usual way of dealing with these sort of jobs is –
        At the same time as new male pintles/tapered valve inners are made, a blank for a reamer should also be turned-up; i.e. at the exact same topslide setting – this can then be milled to just below the centre-line to produce a ‘D’ reamer that will produce a seat for the valves. I’d make it in silver steel and then harden it – it can then be stoned and polished with the objective of giving a satisfactory finish to the seat.
        #852618
        dee
          @dee
          #852614
          …Of course and thanks, but that would be the clarity of hindsight in this context.
          This is a request for assistance/ advice using what is existing and making it fit gas tight, whilst retaining the interesting character of the device.
          #852621
          Andy Stopford
            @andystopford50521
            First of all, try using engineer’s blue, or a blue or black spirit-based marker pen, to find out where the components are actually touching, e.g. at the wide end, narrow end, just in patches, etc. The best course to follow rather depends on what you find.
            I’m presuming the ‘keys’ are original – do you know whether the tapers on them are in good condition?
            #852629
              Several clues in Dee’s photo that his ring isn’t vintage.  Therefore replace it, or scavenge new valves from a new one if the all Brass look is important. Fitting new avoids making leak-proof home-made tapers without having the necessary skills or equipment.
              Example below is from amazon, much the same available from the other usual suspects!
              Screenshot From 2026-06-18 19-58-13
              If home-made valves are essential, I’d start again as described by Diogenes.  Depends on how far off the as-made thus far dimensions are, but making inaccurate tapers fit together gas tight is liable to be hard work. Look up Engineering Blue if this is about developing skills.  Tapers are best measured with suitable equipment, there are no easy shortcuts.
              Though her lessons are painful, hindsight is a wonderful teacher! However, I dislike her pointing out my mistakes.  I found buying books and magazines to be a good way of avoiding surprises.  And the forum has been invaluable.
              Sorry if my answer isn’t what was wanted.  Be interesting to see what others suggest, but I think Dee has a seriously difficult problem given he doesn’t have the necessary equipment.
              alecs
                @alecs
                There is no way to make a gas-tight seal between two mismatched tapers without proper workshop equipment. Give up while you are ahead before you have an explosion from leaked gas.
                #852638
                DC31k
                  @dc31k
                  You have the existing male valve. Mount that in a lathe*, dial it in true, copy its taper onto a suitable lap and finesse the new female taper.
                  I think the same design is used in steam fittings, so past writings from this hobby would show you some ideas (see searchable magazine index).
                  Commission your business associates to make another barrel on which you can refine your technique. Or borrow the reamer and make the initial tapered hole yourself on a piece of scrap.
                  Minimal equipment – the same dial indicator used for concentricity is used for taper copying.
                  Tapers rarely need measuring, but often need matching.
                  The nylok nuts on the tapers may be inappropriate for a hot environment.
                  I suspect you may be using ‘vintage’ in the eBay sense. As you can see above, they are univerally called a ‘boiling ring’.
                  * because of the handle it is difficult to hold. Hot glue lumps of wood to it and use four jaw chuck.
                  #852640
                  Speedy Builder5
                    @speedybuilder5
                    Dee, here is one I made earlier, just over 1 cm long, shown with the ‘D’ bit reamer.
                    Drain Cock Build Large
                    #852641
                      Although skimming the cocks and making a reamer at the same setting to recut the valve bodies is the way to do it, I am not sure there is enough metal to do so. Looking at the OPs photos the cock’s taper is already right down into the valve body and due to the taper ratio only a small amount taken off will see the cock go a lot further into the taper.
                      A taper reamer in action
                      DSC00511
                      Final lapping of teh cock into the valve
                      DSC00514
                      #852643
                      Robert Atkinson 2
                        @robertatkinson2
                        You have made no indication of the use of this burner. In the UK there are safety regulations around gas equipment maintenance. Even if it is running off bottled gas doing work for someone else, even unpaid, will almost certainly leave you liable in the case of a incident and may be an offence in itself. You need to carefully consider your position. Bizarrely despite being primarily an aerospace electronics engineer, I’m trained and registered to work on hydrogen systems. But i am not allowed to service my own gas water heater…..
                        Robert
                        #852656
                        alecs
                          @alecs
                          Safer to buy new valves, available on eBay, Aliexpress, Alabama, Made-in-China.com.
                          These burners complete are often listed as “country cooker”. Or camping stove or burner etc. China appears to be still churning out these vintage burners. If they work  why change it?
                          Screenshot_20260619_190431_Google (1)t9fjmt3u3r0zldj0plku2qj6acjpiu1kScreenshot_20260619_190308_Samsung Browser
                          <p style=”text-align: center;”></p>
                          #852657
                          alecs
                            @alecs
                            Screenshot_20260619_191337_Samsung Browser
                            #852690
                            dee
                              @dee
                              Thanks for the real world positive contributions.
                              I’m a little embarrassed not thinking of a reverse image search. Apologies.
                              “or a blue or black spirit-based marker pen” Yes that’s what i did to start.
                              JasonB  ” I am not sure there is enough metal to do so.”.   This concerned surfaced when lapping the barrel, fine for higher grade emery, definitely a concern for a cutter. Good observation.
                              As for the temporary nylocs, UNF 28 is not so easy find in Phildas turrets, in fact there are few single locking nut solutions that would work on that type of milled thread:
                              L
                              This thing is branded, all the screw heads for the repair were what was lying around and were originally slot head. Certainly some of the above suggestions have strong similarities, but I’m not confident of “made in Chian” valves frankly.
                              The simplest solution may be to turn up a bit of solid brass to match the original taper, temp glue emery and rotate in the new barrel.
                              The thought of using wave washers instead of split spring washers on the taper may help centralise the axial pressure better.
                              #852715
                              howardb
                                @howardb
                                Robert
                                I am reasonably certain that taper gas valves are no longer approved for use on either portable or any other gas appliance in the UK,  but I can’t find any standard or instruction that supports this.
                                It’s approved ball valves only so it seems.
                                https://www.ballvalve.co.uk/gas-approved-brass-ball-valves/
                                #852737
                                alecs
                                  @alecs
                                  L
                                  The thing you will find is that a very small amount of metal removed from the diameter by emery or reamer etc results in a very large movement of the male taper lengthways, resulting in the male plug sticking out too far and becoming unuseable as spring tension adjustment is lost, handle hits the body, and through holes dont line up. Been there, done that many times on similar brass cocks on vintage machinery, so I know of what I speak.
                                  Then there is the issue of getting the two pieces lapped together well enough to form a gas-tight seal. More metal lost, and very difficult to achieve zero leakage.
                                  As you have a friend who can turn you up a tapered plug, you say, I would rather make use of him to cut the handle off the old  plug and join it to a newly made correct taper plug. This could be done by turning a suitable spigot and hole on each piece respectively and silver soldering them together.
                                  Thats the way I would do it, having wasted many hours before faffing about with emery paste and the like on tapered brass cocks.
                                  #852738
                                  bernard towers
                                    @bernardtowers37738
                                    using emery paste will not get you a good seal, its a startv but suggest you end with at least 800 grit lapping paste. my pet cocks on my bike are done like that and do not leak a drip.
                                    #852743
                                    alecs
                                      @alecs
                                      That was with two matching but worn tapers. Dee seems to have two mismatched tapers requiring more metal removal, viz his plan for emery paper glued to a dummy tapered plug, although it’s unclear from his description just how mismatched they are.
                                      Timesaver brand of lapping paste is good for such finishing lapping as it does not leave embedded abrasive particles like actual emery paste as used on hard valves in engines etc.
                                      #852746
                                      alecs
                                        @alecs
                                        On the other hand, I wouldn’t be to averse to buying in new China-made valves. The foundry mark on Dee’s original looks very Chinese to me.
                                        wjyvv59bgl7svzx526xepxdamq6ia7w7
                                        #852753
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, yes there are laws and regulations about servicing gas equipment, I have been trained in the inspection of Oxyfuel gas equipment, which as you can see on the certificate it includes equipment maintenance, but, this is not down to component level, and it means I can replace faulty units, but replacing parts within any unit is not allowed.
                                          img003b
                                          Therefore you should scrape any faulty gas equipment, and replace it with new.
                                          I’m not that likely to have to use this much these days, but it does cover me on my own equipment of this nature.
                                          Regards Nick.
                                          #852775
                                          Bill Phinn
                                            @billphinn90025
                                            I wasn’t under the impression, Nick, that the OP’s stove was a piece of oxy-fuel equipment. Where does the oxy bit come in?
                                            Also, without wishing to detract from your own credentials, if the knowledge (or rather lack of it) shown by two of the biggest welding equipment suppliers in my region (one of whom is BOC) is anything to go by, paper credentials (which they both have in abundance) count for very little.
                                            One of the suppliers told me with absolute seriousness that JM Tenacity 20 flux powder was “only intended for brazing tin”, and the other publicly maintains that propylene (with oxygen) can be used for fusion welding. I leave aside how they handle and store oxygen cylinders.
                                            On the subject of old oxy-fuel kit, I’ve got several brazing/welding shanks and associated neck tubes and nozzles from the 1950’s that are safe and sound in use to this day…in the right hands – a caveat that surely applies to any item of industrial equipment.
                                            #852776
                                              I wonder if gas rules apply here.
                                              We have plenty of model engineers building gas fired models, be they hot air, IC, steam, etc and the builders often make and maintain the burners and valves.
                                              Yet as far as I know it is only storage tanks that are deemed to need testing at club level for public use not what comes after them.
                                              Maybe Robert can say what rules 1000s of model engineers have been breaking for decades?
                                              #852777
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                Hi Jason,
                                                Clearly in the UK there are regulations and without looking it up I didn’t know what they were. I assumed they were part of UKCA / CE but it’s not part of my expertise, I am a UKCA/CA assessor but for interference (EMC), Electrical (LVD), Radio and Machinery.
                                                A quick check revealed it’s Regulation 2016/426 and the Gas Appliances (Enforcement) and Miscellaneous Amendments Regulations 2018 or GAR.
                                                https://www.gov.uk/government/publications/gas-appliances-enforcement-regulations-2018/regulation-2016426-and-the-gas-appliances-enforcement-and-miscellaneous-amendments-regulations-2018-great-britain
                                                The Regulations apply to:
                                                Appliances burning gaseous fuels used for cooking, refrigeration, air-conditioning, space heating, hot water production, lighting and washing and also forced draught burners and heating bodies to be equipped with such burners
                                                Fittings which are regulating, controlling or safety devices and sub-assemblies thereof intended to be incorporated into appliances or assembled to constitute appliances.
                                                The requirements apply even if making an item for your own use. Some items require an independent type examination by a Approved (UKCA) or Notified (CE) body.  I’ve not drilled down into the regulations to see what needs type examination.
                                                Basically you can’t DIY fuel gas equipment.
                                                Robert.
                                                #852778
                                                duncan webster 1
                                                  @duncanwebster1
                                                  I suppose a barrack room lawyer would argue that the devices we are likely to make are intended to produce steam, not included in the above list. Having said that a friend of mine was very badly burned by a faulty gas camping stove, the little backpacker type, so it’s not trivial
                                                  #852780
                                                  Bill Phinn
                                                    @billphinn90025
                                                    On Robert Atkinson 2 Said:.
                                                    Robert.
                                                    A lot hinges on what you mean by the verb “DIY”. Could you elaborate?
                                                    What is it you’re saying Joe Public is and isn’t allowed to do with, for example, Calor gas cylinders and the equipment designed to run off them?
                                                    For the record, this is the harmful nonsense Adams Gas say about propylene.
                                                    #852781
                                                      So does an IC engine, loco, or steam boat fall into the heading of an appliance?
                                                      For as long as I have been making models which is over 40 years the hobby has been making use of DIY ( home made) fuel gas equipment yet never have I seen mention of it needing to comply with any regulation, just common sense.
                                                      I’m not just talking propane and butane but there are also hobbyists who make use of hydrogen and acetylene to run their engines, sometimes mixing their own hybrid gas from two or more of those to create something similar to illuminating or town gas.
