Taylor Hobson Pantograph Engraver Model D
Home › Forums › Workshop Tools and Tooling › Taylor Hobson Pantograph Engraver Model D
Viewing 25 posts - 1 through 25 (of 42 total)
  • #850565
    jaCK Hobson
      @jackhobson50760
      I couldn’t resist this. Now cleaned up and tightened up with new wiring.
      I got to work out how to hold the tapered shank cutters in my Quorn. Or work out how to fit and ER11 spindle.
      711349159_10242950668487259_6904288067388861230_n711565949_10242950667567236_8539061884589327232_n710756314_10242950666487209_6363385004264669633_n710782057_10242950665727190_2298803573996870131_n710481838_10242950664727165_1082222814136017798_n710481839_10242950663887144_1221894665530640136_n710799494_10242950662807117_8784031301749121240_n715304241_10242950661047073_6414998746585453165_n
      #850580
        Nice !
        You may find this page useful, if only for inspiration:
        http://www.pantograph.co.uk/pdfs/spindles_accessories.pdf
        Nigel Graham 2
          @nigelgraham2
          Oojh, thankyou for that. It could be useful for me too.
          I have a much earlier version, named “Taylor, Taylor, Hobson”, presently in bits scattered around the house and workshop.
          The only snag with these machines is they are very greedy for space.
          Mine had lost the spindle nose nut (I don’t think it uses a collet) but I was able to make a replacement, from phosphor-bronze. I had to buy a tap for the thread, apparently a fine UN form.
          #850608
          jaCK Hobson
            @jackhobson50760
            I nearly los
            On Nigel Graham 2 Said:
            Mine had lost the spindle nose nut.
            I nearly lost the spring clip which goes under the nut. The most challenging bit of disassembly/assembly was the ball bearings in the pantograph – I really need new balls but couldn’t wait. I also need a new leadscrew and nut one day – the trapezoidal thread is now a thin triangle.
            #850610
            jaCK Hobson
              @jackhobson50760
              On Michael Gilligan Said:
              Nice !
              ‘Taper Shank Adaptor’ would be handy for sharpening … but half the price I paid for the machine!
              #850618
              jaCK Hobson
                @jackhobson50760
                Anyone know the taper angle on these cutters? My taper guage, which I thought would come in handy one day, is a little large.
                IMG_20260603_081145
                #850629
                Bazyle
                  @bazyle
                  At work in 2000 we still had the little adaptor to turn a TH into a mini mill (really just for trimming up your nameplates etc) but the company moved premises a year after I left so probably the whole lot got scrapped.
                  #850630
                    On jaCK Hobson Said:
                    Anyone know the taper angle on these cutters? […]
                    Yes … the good people who make that nifty little adapter !
                    P.S. … I may have a note of it “somewhere” but don’t hold your breath !
                    #850636
                    jaCK Hobson
                      @jackhobson50760
                      My estimate on taper :
                      Minor dia: 4.08mm
                      Major dia: 5.57mm
                      Length: 22.8mm
                      Taper Angle: 1.8715 degrees
                      Taper: 3.267 %
                      I don’t think I can get a reamer for that, or bore it… so maybe I have to shell out for an adaptor
                      #850637
                        Jack
                        A man of your obvious ability could surely make a ‘D-bit’ reamer from the back-end of an existing cutter.
                        renardiere7
                          @renardiere7
                          Jack, I have some TH cutters which are no use to me as I run a GH Alexander Pantograph. If they are any use to you give us a shout.
                          #850697
                          jaCK Hobson
                            @jackhobson50760
                            Thanks! But I have a lot of (mostly blunt) cutters:
                            On 3 June 2026 at 10:38 Michael Gilligan Said:
                            Jack
                            What I don’t have is a single taper shank that has something on the other end I can get hold of in a chuck/collet!
                            I found more bits… including the start of some home made attachments… not sure what the intent was
                            IMG20260603173922IMG20260603173950
                            And a brass tapered shank disc holder ? But the shank is not quite big enough to fit in spindle
                            Off to clean my hands now…
                            #850709
                            renardiere7
                              @renardiere7
                              Let me look at the bits and pieces I have. I dismantled an earlier version of a TH pantograph than yours, It had built in a single lip grinder. I’ll see if there is anything in the parts that may be of use to you.
                              #850730
                              Charles Jambon
                                @charlesjambon
                                I also bought a Taylor Hobson model D because it was just too good to miss. When I measured the taper cutters I found the taper was a half angle of 2.14 degrees or 0.075 inch/inch. I then made a reamer to this taper and used this to make a socket to grip the cutters for sharpening. But I also found the spindle bearings were badly worn so I ended up making a completely new spindle with E11 collet fittings and “normal bearings” that I have been using for several years with far cheaper 1/8 inch parallel shank (and other) cutters. The spindle design was summarised for the Stevenson Trophy in 2024.
                                #850775
                                Dave S
                                  @daves59043
                                  Can’t you make a tapered d bit to bore a soft collet to hold the tapered portion of a real bit in the grinder so you can then finally sharpen it?
                                  Bit meta and possibly i misunderstood.
                                    It took a while for me to locate this again … mostly because it’s in the name of KAPELLA
                                    No dimensions shown, but it’s a useful reference:
                                    IMG_1671
                                    jaCK Hobson
                                      @jackhobson50760
                                      From the drawing I measure included angle of 4.129 deg. Taper angle 2.065
                                      Which is close to 7/8″ per foot
                                      #851030
                                      Charles Jambon
                                        @charlesjambon
                                        That is astonishing. It is also maybe encouragement for those who try to make mating tapers with such shallow angles that the angle seems to be far more accommodating of unavoidable errors than the regular machine releasing tapers.
                                        #851409
                                        jaCK Hobson
                                          @jackhobson50760
                                          I can find the cutter grinder mod, but not the spindle design. I’ve ordered an ER 11 holder… was probably just going to bodge two sets of deep groove bearings around it somehow which will almost certainly be less than ideal. I’d really appreciate a bit more guidance!
                                          #851428
                                          renardiere7
                                            @renardiere7
                                            Jack, firstly apologies in the delay getting back to you. I had a look through the bits and pieces I have. It looks to me as if the grinder holder is just a simple V groove that locates the tapered shank of the cutter. Sorry I have repeatedly failed to remember to take my phone with me to get a picture.
                                            Secondly, I seem to recall that Stefan Gotteswinter did a video about building a spindle for his Deckel pantograph which was based around a parallel shanked ER11 holder. Different machine but the principals are the same.
                                            #851432
                                            Charles Jambon
                                              @charlesjambon
                                              I will have a look to see if I can find my design drawings for the E11 spindle. I do remember it was quite difficult to find bearings and wavy washers (to provide preload) that would be robust but still fit inside the overall envelope of the original spindle with its integral bearings.
                                              #851592
                                              Charles Jambon
                                                @charlesjambon
                                                I managed to find the workshop drawings for the E11 Taylor Hobson Spindle. They were done old school pencil on paper but trust you can see the most important dimensions. They are a bit of a cocktail of metric and imperial in order to get all the threaded items into a confined space and use available threading equiment where applicable. All threads were lathe cut and finished with a die or tap if available. The pulley is keyed to the spindle in a similar way to the original with a captive short flat key across a flat at the front end of the spindle. Not all the pieces are drawn up – in particular the spacers that support the wavy washers ( W61590) that provide the necessary preload. I found 15 N preload was about right but had to juggle the number of wave washers and flat intermediary washers to get the right set up. I also had to internally grind the wavy washers to clear the spindle because the standard washers have bores that are too small. It is well worth while calibrating the stiffness of the wavy washer stack (actually measuring with a load gauge and height gauge and not calculating N/mm using the standard formulae)  and measuring very carefully the shoulder and spacer distances to get the right preload. The bearings are standard thin race SKF 61901-2RS1 (12mm x 24 mm x 6 mm) and Dunlop 61700 -2RS (10 mm x 15 mm x 4 mm) and they have worked very well over many years. But the original Taylor Hobson design is by far the most elegant and I hope to regrind the races at some stage and get the old one working again – albeit with taper shank cutters.
                                                TH spindleSTH HousingTH PulleyTH End Closure
                                                #851675
                                                jaCK Hobson
                                                  @jackhobson50760
                                                  Wow. Proper drawings!
                                                  #851688
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    Taylor, Taylot Hobson were high precision engineers (Their photograhic enlarging lenses would ouperform high quality Japanese ones!)
                                                    The thought of the taper being 7/8 per foot is quite appealing for a British comany, if not Morse taper. Diameters will give a clue as which one – 2MT is 2 degrees 52 minutes from memory
                                                    (I would expect to find that the threads used on the machine were Whitworth form, possibly BSF rather than the coarser BSW)
                                                    #851694
                                                    jaCK Hobson
                                                      @jackhobson50760
                                                      Threads were getting worryingly thin on the main leadscrew so I bodged a new one from std TR12 threaded bar off Amazon. Now to bodge a nut. I wonder how long a 100% infil PLA 3D print would last? Shame I can’t print delron.
                                                      720217457_10243075505688111_7603203180662591857_n721297305_10243075504288076_6752982849813668546_n721369862_10243075504888091_692315755812291808_n
