Perfectly viable approach.
I fabricated a fairly complicated motor-shield / splash-back for my Myford lathe, from 3mm PVC sheet.
I used standard plumbing-pipe solvent for the joints, but reinforced the corners with “angle-plastic” made by forming strips over the edge of a length of planed wood, softening the PVC with an electrician’s heat-gun.
No “welding”.
To improve air flow round the end of the motor I dished the adjacent panel by pressing the heat-softened plastic between two improvised plywood dies whose diameters happened to be suitable, using the bench-drill as an arbor-press.
(And no I would not use the drill as an arbor-press otherwise!)
