Mamod spring belt profile
Home › Forums › Miscellaneous models › Mamod spring belt profile
  • #843488
    paul rushmer
      @paulrushmer83015
      I want to use a mamod spring belt to drive a small generator, I do not know what profile to machine the pulleys. Any surgestions would be helpfull, I was thinking a 60 degree vee screw cutting tool would do?
      Thanks Paul
      #843493
      bernard towers
        @bernardtowers37738
        Its a half round groove of about 3/32′
        #843504
        DC31k
          @dc31k
          If you studied some photos of Mamod items that use the same belt, you might be able to determine what they did.
          Do you intend to draw power from the generator? Did Mamod use the belt in a way that it would encounter similar resistance?
          #843505
            I have used 1/16wide x 1/16″ deep with a half round bottom, so a U shape not half round. This is also the size given on th eStuart Williamson which used the same type belt for the governor. The actual belts is approx 1.5mm wide so very little side clearance.
            Depending on the size of your generatr and the load it creates you may have problems with belt slip. But as it drove the TE along there would be a reasonable resistance to that
            Drives this cooling fan OK
            #843533
            Bo’sun
              @bosun58570
              Good morning Paul.  I suspect, as suggested, a U shaped/round bottomed groove would be best.  A vee groove might tend to grab a round belt and sap some of the all important power.
              #843614
                Just as an aside … I was interested to see reference to sharp scissors!
                IMG_1560
                Credit: https://www.berrybrooksteam.co.uk/blog/toy-steam-mamod-through-the-decades/
                #843633
                paul rushmer
                  @paulrushmer83015
                  Thanks all
                  Tool sharpening tomorrow, the generator is a small brushless motor driving a few leds.
                  Paul
                Home › Forums › Miscellaneous models › Topics
