14.0mm to 14.1mm id required on a peice of ali
Home Forums Introduce Yourself – New members start here! 14.0mm to 14.1mm id required on a peice of ali
  • #838331
    mgbglasgow
      @mgbglasgow
      Hi from glasgow
      anyone open to small peice of lathe work required in Glasgow?!?
      #838500
      bernard towers
        @bernardtowers37738
        Go on tell us more
        #838502
        mgbglasgow
          @mgbglasgow
          It’s an anodised collar either internal bore of 14.0mm , need it out to 14.1n mm
          #838506
          DC31k
            @dc31k
            1/2″ (maybe 10mm) wooden dowel. Slit with a saw. Wrap with abrasive paper, end tucked into slit*. Spin in a cordless drill.
            * it will very quickly become obvious in which direction the abrasive should be wrapped.
            #838549
            bernard towers
              @bernardtowers37738
              Put in 14mm collet and take out 0.1mm
              #838553
              Nigel Graham 2
                @nigelgraham2
                Anodising will blunt tools and cause a poor finish and possibly inaccurate size if you try to turn it: it is aluminium oxide, a substance itself used as an abrasive.
                Lapping as Mgbglasgow suggests is probably the best method. I assume something is available – a mating part perhaps – to use a plug-gauge. Or make one, of course.
                #838569
                mgbglasgow
                  @mgbglasgow
                  Seriously, is this the depth on here ?!?
                  #838570
                  mgbglasgow
                    @mgbglasgow
                    Jesus
                    #838586
                      Sorry wrong end of the country but post is often cheaper than fuel.
                      You will find a lot of answeres but often little in the way of offers.
                      I doubt it is hard anodised and even so anyone doing it can charge for a replacement tip if they feel it has blunted one. Personally I don’t seem to get the problem turning old bits of aluminium that have oxidised over time and as it is only skin deep a new insert for the finish cut will do.
                      I also don’t know how you would make a plug gauge if you don’t have the equipment to bore the part. Likewise if you are unable to bore it you are unlikely to have collets to put it in, even those magic ones at 14mm which will hold a part with a 14mm hole in them?
                      Length of bore and overall size would help so anyone offering will know if it will fit their machine. Also is it a clamp on collar that may have been split?
                      #838588
                      Hollowpoint
                        @hollowpoint
                        The quality of answers is directly related to the quality of question. You’ve given us nothing.
                        What is it for? What shape is it? How long is the bore? How accurate does it need to be? Do you have a picture?
                        No one is likely to commit to helping without detail. An already round 20mm long spacer bush would take 10 minutes to bore to size. A 100mm deep bore going diagonally through on a rohmbic shaped space shuttle part still attached to the aircraft would take me over ten minutes.
                        #838591
                          Removing what might, or might not be, 0.1mm from an aluminium part is not a trivial matter with a lathe.  Initial concentricity would require very careful set up.
                          Final,concentricity required is not established.
                          It is not a simple case of holding the part in a 3 jaw chuck.
                          Clearly, from your comments, you are not exactly helping yourself in getting this done accurately and (presumably?) cheaply.
                          I am with the suggestion that you do it yourself by lapping.  An alternative would be a suggestion that you take it to an engineering company and ask them for a quote.
                          Bye.
                          #838593
                          Nealeb
                            @nealeb
                            Or maybe ask the question in the “help requested” section rather than the “introduce yourself” area?
                            #838599
                            DC31k
                              @dc31k
                              How would something with a 14mm bore fit into a 14mm collet?
                              If, through some slight oversight on your part, you neglected to mention that it should be an internally-gripping (expanding) collet, how do then machine the part when the collet is gripping the surface to be machined?
                              Please read the question again and reconsider.
                              #838601
                              DC31k
                                @dc31k
                                You are the one who has specificed the depth. 0.1mm on diameter is a depth of 0.05mm. This is within the sensible range for abrasive methods and does not require turning, especially because of the surface coating.
                                #838604
                                Jouke van der Veen
                                  @joukevanderveen72935
                                  It was a simple question to start with:
                                  Is there somebody in Glasgow who is able to increase the internal hole in an anodized aluminium collar from 14.0 to 14.1mm.
                                  It suggests that the collar does not fit on something with an external diameter larger than, lets say, 14.05mm. Perhaps the diameter of this part can be reduced a bit by abrasing?
                                  Or the collar can be heated and then pressed on the counterpart?
                                  #838770
                                    Spot-on, DC31k
                                    a Delapena machine would be ideal, but abrasive on a dowel would soon get the job done.
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi mgbglasgo, less of the sarcastic and possible offensive comments, may help others to help you.
                                      Regards Nick.
                                      #839089
                                      Trevor Drabble 1
                                        @trevordrabble1
                                        Hello mgb . Any chance of a couple of photos ?
                                        #839106
                                        Nigel Graham 2
                                          @nigelgraham2
                                          Sorry – I mis-referenced my remark.
                                          Lapping was Dc31k’s suggestion, not Mgb’s of course!
                                          I still agree with the technique though.
