VFD and replacement motor recommendation
Home Forums Beginners questions VFD and replacement motor recommendation
  • #221716
    Dan Snelling
      @dansnelling97347
      Hi all,
      I have tried searching, ended up more confused.
      I have decided to upgrade my Boxford lathes to VFD to have more control over surface speed as well as all the other benefits that come with it.
      Trouble I am having is the number of different brands of inverter available. What do people recommend? Any I should avoid?
      Same story with the motor. I am after a 80 frame size foot mount in 1hp. Recommendations on this?
      UK supplier with best prices and customer support?
      Thanks in advance
      Dan
      #7972
      Dan Snelling
        @dansnelling97347
        Help needed deciding what to get
        #221720
        KWIL
          @kwil
          Newton Tesla, very helpful and experienced at all power levels.
          #221737
          Thor 🇳🇴
            @thor
            Hi Dan,
            I am running a TEC 3-phase motor with a Transwave inverter. It is almost 3 years old and has been working well. If I had the funds I would upgrade my small lathe to 3-phase/inverter drive.
            Thor
            #221739
            Harry Wilkes
              @harrywilkes58467
              Purchased my motor/ inverter from Transwave two years on more than happy with it. smiley
              H
              #221742
              Roger Vane
                @rogervane67137
                Another vote for Newton Tesla. I've now upgraded 3 machines using their products and found them to be very helpful and supportive.
                #221743
                Raymond Anderson
                  @raymondanderson34407
                  The smaller of me 2 lathes [Warco GH750 ] is powered by a Siemens 3 phase motor, and a Eurotherm Drive [Now made by Parker SSD ] the set up is now around 15 years old and has, and still is, working perfectly. Motor and Drive were supplied by Transwave.
                  #221744
                  duncan webster 1
                    @duncanwebster1
                    Yet another vote for Newton Tesla, I've now done 4 machines with their inverters, the box of tricks gets smaller every time. If you ask them nicely they will set it all up for you and sell you the pendant controller.
                    #221746
                    Mike Bondarczuk
                      @mikebondarczuk27171
                      Went with Transwave for my Myford Tr-Leva VFD upgrade and also with Transwave for a rotary 3 phase converter for my Hardinge, and in both cases the company was a pleasure to deal with.
                      No other link apart from being a very satisfied customer.
                      #221752
                      Martin Connelly
                        @martinconnelly55370
                        Remember to get a motor that has the same RPM at 50hz as the motor you are replacing. The number of poles of a 3 phase motor give different nominal speeds.
                        Martin
