ultra sonic cleaner
ultra sonic cleaner
Home › Forums › General Questions › ultra sonic cleaner
  • #854096
    Dalboy
      @dalboy
      I am looking to buy an cleaner and have been looking at this one has anyone had any experience with this brand
      #854115
      bernard towers
        @bernardtowers37738
        Mostly depends on how big the stuff is you want to clean and how deep your pockets are. Ive got one about a third of the size that looks very similar (machine DRO) and has been ok for about ten years.
        #854150
        Robert Atkinson 2
          @robertatkinson2
          That particular one has some issues in the description.
          It also does not have a proper power switch which would be a big no for me.
          Robert.
          #854152
          Brian Baker 2
            @brianbaker2
            Greetings Delboy, I bought mine, about the same size from Machine DRO about 2 years ago, looks about the same size, works well, and they sell all the cleaning solutions as well.
            Brian B
            #854154
            Neil A
              @neila
              Machine DRO is part of the Allendale Group, the ultrasonic cleaners are now shown under Allendale Ultrasonics.
              Many different sizes available.
              Dalboy
                @dalboy
                Robert
                Thank you for that I found one a little dearer with a fuse protection on the machine.
                It is this ONE it also has a gentle button and on for degassing. It looks identical to a Creworks of the same size.
                The 6Ltr size is ideal for the majority of what I will need to clean, as usual it does not matter how big a machine you buy there will always be something that will not fit, but I can live with that small problem (or should that be bigger problem lol)
                Also thank you, @bernard towers for replying
                #854168
                Dalboy
                  @dalboy
                  Just in case I forgot to say thank you to all the other replies. Thank you all.
                  #854169
                  Russell Eberhardt
                    @russelleberhardt48058
                    Most of the advertisements for these show identical models with different branding.  Most are made in China.  They all seem to advertise them for cleaning glasses amongst other things.  I made the mistake of cleaning my glasses in one once,  It stripped half the coating  off the lenses!
                    Russell
                    #854260
                    howardb
                      @howardb
                      If you are buying it from Amazon you have 30 days to return it and get a refund if it doesn’t perform satisfactorily or is faulty.
                      #854298
                      Graham Meek
                        @grahammeek88282
                        I have been thinking of getting one of these for sometime. A 3L model would best suit my needs, but I would prefer to have one with dial controls.
                        Has anyone had experience of this type of ultra-sonic cleaner?
                        Gray,
                        #854305
                        Nicholas Farr
                          @nicholasfarr14254
                          Hi Gray, I was looking at some on Amazon, and few of them have dial controls, from cheap to more expensive. Amazon Digital-Ultrasonic. I’ve only got a little fairly basic cheap one that I got from Maplin’s many moons ago, which does small things to varying results, and I keep thinking of getting a 3L one, which I might do with next months budget.
                          Regards Nick.
                          #854313
                          Diogenes
                            @diogenes
                            Hi Gray, yes I have an analogue Creworks of 2.8l. with chunky dials and clockwork timer – can’t fault it, the mechanism / switches all feel positive and robust and everything has worked as it should for the ?18months I’ve owned it.IMG_2940
                            It has a separate on/off switch at the rear and uses a ‘kettle-style’ socket/lead.
                            ‘Better than expected’.
                            #854322
                            Graham Meek
                              @grahammeek88282
                              Thanks Nick & Diogenes,
                              For taking time out to answer my post. The Creworks model was the one I had my eye on and I will be placing the order later this evening.
                              Gray,
