> Use a rubber mat rather than a self healing one …
The problem is that I rather need it to self-heal!
Is it possible to get one that is both?
I do have a cutting rule (with a rubber back to it), but it's measuring edge is aluminium and can easily be accidentally damaged by cutting blades.
> Double sided adhesive tape …
Seems rather extreme. As it would pick up dust & dirt. And would presumably tend to come away with the plastic after use… If all else fails I may try it though! Is that what you use?
