Hi, as has been said, all these imported bandsaws are similar. I have a Warco which I got in similar circumstances for £20. Because they are similar you can look up a manual for those freely available and the advice will apply to the Warco.
Try looking for the Sealey version, they have pdf files available for all their machines. I can’t remember it’s no. offhand., but it’s a bit more “posh” than the Warco, but probably only to meet latest legislation on safety.
I actually bought a Sealey part to fit on the Warco, which it did with a little fiddling.
Hang on – I’ve just had a dig in my “Paperwork Tray” (actually a 12″ pile) and found the print I did of the Sealey pdf- now that in itself is amazing.
The model is SM5.V3, and was the latest one, but the basics are all the same.
Have a look at
http://www.sealey.co.uk and you should be able to find it. If not, do another post and I’ll have a look.
Phil
PS I got some blades from Axminster and they are doing well.
PPS I have found that Clive is right about using white spirit as a cleanser. Have used it since kero (paraffin) got too dear, and it is better, you don’t really need to filter it, just let the gunge settle to the bottom and carefully decant the clean spirit. Painters do this all the time.
Edited By Robbo on 15/07/2011 23:25:26
Edited By Robbo on 15/07/2011 23:28:58
